Lingenfelter tests supercharged 6.2L Gen 5 engine
Old 10-08-2013, 04:21 AM
TurrizT
TurrizT's Avatar
621 to the wheels would be just about perfect for me...
Old 10-08-2013, 06:45 AM
Rkreigh
Rkreigh's Avatar
621 with a nice broad shouldered torq curve will please many
no need to go to a bigger blower when this one "flows enough" for that power level efficiently
bigger isn't always better, and I'm sure they will offer another higher HP package down the road.
give em a bit of credit, LPE does some nice work
my c4 ZR-1 puts 508 at the tire out of the "old tech" LT5 and it's proven to be "just about right" on the power without resorting to drag radials.
this one will put a bit more jam than that down and prove to be a thrilling ride like most LPE products.
kudos, tell Graham hi and have the old mucker post up a bit. he's no doubt in there fiddling a bit with the tune.
that old brit has forgotten more than most will ever know
good job LPE!
to all the naysayers. when you get your PE credientials and have tuned thousands of hot rods, you can take over LPE and let them know what the next build should be. In the meantime, I'm pretty happy to see this one come down the pike. for those that can't wait for the next chevy hi po C7 variant, it's a good option. it will no doubt be spankin a track soon in the cool fall air and laying down the jam.
Old 10-08-2013, 06:50 AM
C7lover2
C7lover2's Avatar
Was this on 93 octane and any plans to test E85?
Old 10-08-2013, 06:56 AM
Graham Behan
Graham Behan's Avatar
Yes tested on 93 Oct and no plans to test on E85 with this set up, not enough fuel system for that.
I will answer more of the questions / comments later. "after more coffee"
Graham.
Old 10-08-2013, 07:31 AM
Spulbus2013
Spulbus2013's Avatar
So Graham is this going to be your final power figure for this package, 620 @ the engine? Just curious if your still tinkering and pushing more out or if this is in fact your final product. I take it this was done without cats? Yeah I agree id rather purchase a 2.3L vs 1.9L if I had the choice for this package.
Old 10-08-2013, 09:25 AM
21STCENTURYMUSCLECAR
Premium Supporting Vendor
21STCENTURYMUSCLECAR's Avatar
Originally Posted by DCTandAWD?
Why would you use a TINY TVS1900 instead of
I always hated people that promoted tiny blowers that offer limited expandability when compared to better alternatives like a TVS2300 or a ECS Paxton.
Good going LPE, that was fast!
We have made 732 rwhp w. that tiny 1900 on a 2012 ctsv w. auto transmission with cats and without meth or nitrous but it is over spinning the blower and has heads, cam, plenty of other bolt ons and porting.
Trust me they could make a bunch more if they wanted to.........
J.P.
Old 10-08-2013, 12:09 PM
Racerdave24
Support Corvetteforum!
Racerdave24's Avatar
St. Jude Donor '13
Default Good Advice!
[QUOTE=JeffInDFW;1585119792]Your QUESTION is an excellent one. How you ASKED it is the problem. Nothing good happens when you put people on the defensive right off the bat. Instead, how about:
LPE, always loved your twin turbo builds but I've got a question.....I noticed you used the smaller TVS1900 instead of the TVS2300. It seems to me like the larger 2300 would allow the owner to have more options for future growth, and is IMO a better unit. What was the reasoning for going with the TVS1900 instead? Thanks guys.
Same question, you get your point across, and you don't look like your trying to be a jerk.
That's good advice!!!
Graham Behan
OK all, may or may not answer all questions, if not just let me know.
Why TVS 1900, many truck applications that we sell are TVS 1900 on base engines, so first up TVS1900 truck kit from Magnusson. BTW the 1900 is capable of much more power than this only spinning at 15K for this boost level.
Pulse width 5.4 ms at 6000 rpm, fuel press 15Mpa(rail)
This is just an insight into a fraction of our R&D so far, it is not a defined package, just sharing test data so far.
Graham.
Old 10-08-2013, 01:12 PM
LT1_E85_Corvette
LT1_E85_Corvette's Avatar
only 6lbs of boost? this is F'n redick....
Old 10-08-2013, 01:37 PM
JoesC5
JoesC5's Avatar
Received 1,700 Likes on 1,214 Posts
but on a 11.5:1 compression ratio engine.
Old 10-08-2013, 03:41 PM
BeaZt
BeaZt's Avatar
St. Jude Donor '14
Not to shabby.
Old 10-08-2013, 04:07 PM
DOUG @ ECS
DOUG @ ECS's Avatar
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,090 Likes on 658 Posts
Great job Graham! Way to set the curve.
Old 10-08-2013, 08:58 PM
  #33
Baron7700
Baron7700's Avatar
Originally Posted by Skypilot797
Can you tell us what the duty cycle was on the stock injectors?
Its a DI motor, im sure there is plenty of injector left
Old 10-08-2013, 10:02 PM
  #34
3 Z06ZR1
3 Z06ZR1's Avatar
Why would you use a TINY TVS1900 instead of a TVS2300 ???
It's 12.0 compression my man so the 1900 is smaller and packs
a punch!
Old 10-08-2013, 10:04 PM
  #35
3 Z06ZR1
3 Z06ZR1's Avatar
thought they were 12.0 still high to be boosted that and that the 1900 is smaller so it fits!
Old 10-09-2013, 12:37 AM
  #36
C7pimp
C7pimp's Avatar
Graham.
My concern with the 1900 over the 2300 is the efficiency of the blower and the amount of power required to drive it.
I'm not going to pretend I know that much about roots blowers because I've always used centrifugal style blowers, but I thought the 2300 was a much more efficient blower to run. As laughable as it may be to have concerns over mpg and efficiency with a 600+hp car, it still matters to a certain degree.
Turbocharged vehicles are much more fuel efficient than blowers, and get better hp per boost because they don't tax the engine like a blower does to spool and create boost.
If you could still get 30mpg in eco mode that would be absolutely awesome!!
Old 10-09-2013, 01:32 AM
  #37
_zebra
_zebra's Avatar
Graham.
my question is how come you're using what looks like the truck kit as opposed to the vette version (assuming it uses similar heads to the LS3)
well if you're driving in eco mode, either of them only take about 1/2 hp to drive with the bypass open. i see your point, though, considering the 2300 would move the same CFM with a lower RPM meaning less friction/heat with the tradeoff of a little more rotational mass. i have a 2300 on my LS1 & it seems plenty efficient for what it is - 11psi on a stock engine making about 540h/550t and i can still manage 27-28mpg on the highway (driving like a waxer, of course )
To Lingenfelter tests supercharged 6.2L Gen 5 engine
Old 10-09-2013, 10:25 AM
  #38
arghx7
arghx7's Avatar
I'm a little confused as to what you are referring to here, but allow me to point out that the Gen V heads, both in truck and car/Corvette applications, are very different from the Gen IV. Gen V has generally speaking a lower flow intake port as a consequence of port designed for high swirl motion. It also has reversed valve positions and higher exhaust flow.
Old 10-09-2013, 06:03 PM
  #39
Baron7700
Baron7700's Avatar
Apparently my one line saying I think there is plenty of injector left see (post #35) was enough to invite this unsolicited pm
HP tuners is showing a 19 percent duty cycle for baseline pulls on the Z51 M7 trans. Several of my friends who have shops have reported this to me and we were wondering with the boast how much injector was left. Presently, there are no injectors available for the LT1.
My question was directed at them, not you, for a clarified answer, which they did give and you didn't understand.
Your answer was not called for nor wanted. Also, a DI engine can handle a lot more boast than a LS engine can. The compression ratio on the LT1 is 11.5 to 1.
Maybe you just need to realize your "all god knowing" is nothing here to many of us! So butt out when the questions aren't directed at you......
In short, use your dad's boy attitude to impress the bar crowd.
You must be a used car salesman!
So be careful how you guys debate, or get a flame PM.
My experience with boosted DI cars in the last few years tells me not injectors, but fuel pumps, are usually the issue with getting enough fuel. Wow people here are touchy.
Awesome Job to Lingenfelter cant wait to see how this reacts in the car.
Old 10-09-2013, 06:53 PM
  #40
RichieRichZ06
Supporting Vendor
RichieRichZ06's Avatar
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,426 Likes on 597 Posts
St. Jude Donor '08
a punch!
Actually it's 11.0:1 according to GM.
Quick Reply: Lingenfelter tests supercharged 6.2L Gen 5 engine
