Where does your coolant gauge sit at?
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
Mine always sits here or less. As hot as it gets New 15-11113 OEM thermostat. I remember my previous C7 hovering in the 220 mark range.
Does this look okay or is it running too cool? It had a 160 thermostat by a previous owner and I didn't like the way it ran cold. Not sure if I need to have the fan turn on looked at. It may be tuned along with the 160 thermostat.
Car is not giving me any issues whatsoever, but want to make sure.
A tuner said he would correct it for $200 if it's off. $100 for labor and $100 for 2 HP Tuner credits.
Received 8,951 Likes
2019 GM Promotional Picture
I was driving my 2015 Z06 (no analog coolant display available) yesterday afternoon with the speed set at 75 mph, the M7 in 7th gear, cruise set, mid 50s ambient temp and the coolant temp was reading 186 deg F. Oil temp was reading 176 deg F. I rarely see over 200 degree coolant temp when driving on the street and usually see coolant temps in the 220 range when I am on track for at least 5 minutes with oil temps running in the high 260s. Stock thermostat with GMPP Secondary Radiator in place.
Bill
The following 2 users liked this post by Bill Dearborn:
corvettezman (02-19-2024),
H Watkins (02-20-2024)
In the 2019 GM picture you posted, the gauge seems to be running where mine does.
I will for sure try the touring mode though.
The following 2 users liked this post by IA-SteveB:
76-Vetteman (02-20-2024),
Bill
Bill
Got on the interstate with outside temperature at 40 cruising at 70MPH and my reading dropped to 180.
Sounds about normal to me at this point.
Where dose your coolant gage sit?...
We the readers need more answers then nine folks.
Received 5,232 Likes
As memory serves, right around 200, with the oil very slightly higher.
My 14 Z51 m7 lazily ran up to 185 on the digital gauge, meanwhile the analog just parked right under 220. After having the max fan run on and zero temp readout problem and a subsequent thermostat change, it now runs about 215 (digital) and the same just under 220 analog reading.
Revisiting this once more.
Took the car for a nice drive this morning at 35* outside temp.
The car heats up fairly quickly just enough to eliminate the tach bar.
So what I notice in touring digital readings, my temp will run up to 184 then drop to 174 then to 184 again and so on.
The thermostat is brand new OEM 15-11113.
Is this a normal range or is it a bit on the cool side?
If the new thermostat is being triggered too soon, I don't know what's a good brand to replace it with.
Try using a vacuum pump ‘AirLift’ to remove any trapped air.
