Oil changes? Recommendations? Jiffy lube?
#41
Pro Mechanic
fnbrowning (03-11-2024)
#44
Change the oil? Just add more when the level goes down. Also throw in a can of STP if the mechanical sounds seem to be getting louder.
Wujekcity (02-23-2024)
#45
Received 4,738 Likes
#47
Are you feeling lucky? Do you like to take risks, gambling with health and/or operation of your vehicle? As someone else suggested, at the least, buy a set of Race Ramps and DIY. Personally, I invested in a QuickJack to perform all fluid changes, cleaning, etc.
However, with my other vehicles, I actually purchase filter/oil/fluids and take to a locally-owned place that will service and I trust. In all the years—45–I have had service done at nationwide places—JiffyLube, Meineke, Take5, etc.—I’ve had fewer than ten instances where the filter was not seated properly, oil plug not screwed in properly or tightened correctly. Once, oil was accidentally filled into transmission fluid.
At a minimum, a low profile floor jack and jack stands can be used. For me, safety and peace-of-mind led me to first purchase RaceRamps and finally, a QuickJack. The only complaint I have regarding QuickJack is its weight. However, it does have rollers on one end which helps with storing.
#48
Received 5,605 Likes
Do it yourself. It is pretty simple and you can learn about your car. Here’s a nice article from Hib on how to change the oil on a dry sump engine like yours.
https://www.corvettemagazine.com/c6-...ystem-service/
#49
I was allowed 4 free oil changes on my 2015 z51 dry sump. Two times when the dealer did the change, the oil level was way too high and i had to take oil out. I checked the oil level the way it should be checked with the proper temperature and the 5- 8 minute wait period after the engine was shut down. I got myself some race ramps and starting doing the oil changes myself and now know that it is done correctly. Have also used the race ramps for changing my transmission fluid on my M7 and also my differential fluid. Since the dealer could not seem to get it right, then I feel that lots of other oil change places would not do it correct either. Just my 2 cents
#50
#51
Agreed...im not very mechanical, but I know how easy it is to actually change the oil. My issue would be to get it into the air. Sounds like racing rampw are the easiest way? Anyone know about how much a set would cost ? Also you juar need a pair to lift up the front end correct??
#52
My car is a dry sump? Guess I need to look u0 what that actually means haha
And fyi everyone..I have an appointment next Tuesday at The Corvette Center in Newington CT.
#53
I change my own oil on both vettes.
autozone is the cheapest place to get 10 quarts (get the deal of 5 quarts for $38.99… two times). They also have the PF64 filter which is the only one you should be using.
good luck
good luck
#54
IDK about dry sump but for 20 years, I haven't had an MB problem like that because my TECH got it right. You had issues, IMO because, I suspect, because you don't know your TECH. You know of your DEALER. Tell me if this is how it happens for you. You drop the car off, they call you when it is done by some luck of the draw person. You go home and find problems and now you brand the DEALER. I got to know my TECH from small jobs. I watched how he works. I give him some tips and get to know him personally. When I drop it off to the dealer, either he works on it or nobody does. I get him to do some side work. OTOH, there was a tech there that was very experienced and knowledgeable but would take shortcuts. I also had a backup, BTW. The SA is there to book the appointments and do other tasks. The TECH communicates with me directly. Currently, I am trying to get to know my F250 TECH and the Corvette TECH.
Factoid (02-23-2024)
#55
Let me put it this way... There is a reason quick-lube places are cheaper (sometimes by half) than a lot of other places for alignments, oil-changes, tires, brakes/rotors (labor costs).... etc.
#57
Do those places require a $50 an hour, highly qualified ASE tech? IIRC, their business model isn't about oil change. Upsell air filters, etc.
#58
And the quality of work (my experience across multiple states with multiple cars) is usually worse at chain lube shops. I am sure there are some great people out there that work hard and do good work at those places. But typically people who are paid better do better work. I know that's not across the board with everything and there are so many other factors but it's generally true with any aspect of life - In other words "You get what you pay for."
I would rather pay a few bucks more to an independent shop that has been in business for 50 years - but that's just me and unfortunately not everyone has that option and those places are dying out.
#59
I took my son’s 2004 G35 sedan years ago to a quick lube place on the spur of the moment thing instead of the local Infiniti dealership. PITA!! Got the car done and back home with it dripping oil in my driveway where I first spotted it. I thought they failed to torque the filter correctly and took it back to them. They checked it and told me it was just oil dripping from the lower engine compartment closure panel. Such a hurry they took the shortcut to not remove the panel and just let oil fall onto and collect on the upper side of the panel. And still dripping when I got home the second time as they failed to clean it after I complained about the leakage. So I took the panel off myself and cleaned it. Never again will I trust a quick lube place touch a car of mine. What a bunch of clowns. Should have just changed the oil myself after all the effort I had to take to clean that closure panel of the oil drippage.
#60
Yup.
