C7 door won't open
Roadster Madness. 😠
Received 1,526 Likes
St. Jude Donor '13, '20-'21
If you are stuck inside, there is an emergency release lever on the floor by the sill.
Is everything else working? Give us some details.
Does your FOB activate the door?
can u open it from the outside?
if so I would assume the interior button should be taken out and looked at.
if u cant open it at all electrical button wise on either side, try the trunk release tab to get it open in general.
but certainly would start looking at the buttons first then the actuators in the door next perhaps..
The following 2 users liked this post by RonC7:
CorvetteMike2024 (10-18-2023),
DougVette2019 (10-18-2023)
The following 2 users liked this post by Bayshore Vette:
Vette Jockey (10-18-2023)
Did you press the unlock button?
Sometimes my driver door will not unlock/open from the inside after I park the car and turn it off. I just press the unlock button and all is well.
Received 19,439 Likes
'20-'21-'22-'23-'24
If you push the lock/unlock button on the door panel and it still won't open when you push the open button, then I would think the open button is the culprit.
