Minor impact airbags deployed
5th Gear
Dog wandering loose on freeway no way I could avoid it, probably 75-80 pound dog, hit it at about 50 mph. Minor damage to the grill no body damage at all. Front and side airbags both deployed, insurance is going to total the car. Do airbags normally deploy with very little impact.
Grill damage
Grill damage
The following 3 users liked this post by CorvetteMike2024:
Airbags are replaceable. Insurance companies for some reason take the easy way out and total the car. Deployed airbags do not make the car "dead"! What is wrong with insurance companies these days??? Is there any other damage other than airbags and cosmetic?
toadmeister2k (09-26-2023)
CJ Willys (09-23-2023)
5th Gear
There is no damage to the car other than a broken $200.00 grill. I have not received any numbers from the insurance company. They have not inspected the car only told me it will be totaled.
Received 19,359 Likes
'20-'21-'22-'23-'24
Based on what you said in terms of damage, it’s nuts that they mentioned totaling the car. If they do, it would be worth it to see what you can buy the car back from them and then fix it. Check into how that would impact the title too - could result in a branded one.
The following 4 users liked this post by Vetteman Jack:
Bayshore Vette (09-25-2023),
CorvetteMike2024 (09-23-2023),
toadmeister2k (09-26-2023),
TxLefty (09-25-2023)
Can't say only damage is the grill. Maybe something bent under the bumper/front end? Airbag sensors are set to not only go off with an impact but also the force of an impact. Something 70lbs hitting the car going 50 is a lot of force.
The following 3 users liked this post by fuzzy03cls:
Received 4,728 Likes
It might be worth buying the car back from the insurance company if the price is right
I was rear ended in my Audi. All you could see were some scratches from his license plate. Under the bumper cover was another story. The metal bumper and some sensors needed replacing. Was only a few grand but on the surface it didnt look like any damage.
CorvetteMike2024 (09-24-2023)
It used to be the primary trigger for airbag firing was a 15mph delta in under .1 second, so you had to be going at least 15. Now I think they say anything similar to hitting a wall at 10 mph. More recently, they've gotten smarter and can detect a wider variety of impacts,such as a tree or another car. They'll also adjust if the occupant is wearing their seat belt or not. Oddly enough, my '07 blew both front airbags in a side collision, even though I had no passenger. My friends '08 honda blew the passenger curtain bag when she slid it into a curb in the rain, but had no passenger.
It does seem to be overkill to total the car with this small amount of damage, but its not just the bags that need replacing. Many of the sensors and even the airbag computer itself are one time trigger only on a lot of vehicles. Still hard to imagine $20k or more worth of damage in those pics.
The following 3 users liked this post by Ratboy:
Insurance totals at 80% value and above. So if you take a value of 45,000 you need 36,000 in damage atleast. I'm not seeing it 3 airbags and minor front end damage. Insurance companies aren't totaling a car and paying blue book to replace if they don't have to. I would like to know what the body shop is quoting for a repair cost. Maybe I'm just not understanding how expensive these cars are to fix, this seems like over kill to total your car.
Not saying that happened to you, but I wouldn't be so sure you're in the clear. The frame could have also cracked somewhere in a place that wouldn't be visible without a fairly comprehensive teardown of the car. That's why insurance might total the car out for seemingly minor hits where the airbags deployed - coughing up the money for a new car is expensive, but it's peanuts compared to a lawsuit against them if they tell you the car is OK but you end up getting hurt due to a bad frame.
The following 3 users liked this post by SivaSuryaKshatriya:
Corvette Junkie
Received 2,026 Likes
No damage that you know of yet. These cars and their aluminum frames are very temperamental. For example, I saw one that had a front impact that seemed fine except for a dinged bumper, but it turns out the front bumper reinforcement bar got pushed in which in turn caused the frame to diamond.
I don't understand your statement. His car wasn't damaged until the accident so why wouldn't it be worth 45,000 that makes no sense. I'm also guessing on price but regardless it's 80% of value or more to total. So what was your point? What the value will be after the accident. That's is irrelevant for this thread no one is talking value after the accident. Only why is it being totaled with so little damage
5th Gear
my original question was : Why did the airbags deploy?
I would take the money and walk away. Then begin your search for the next toy. Good Luck.
