Help with radio
Help with radio
I have a 2017 Grand Sport convertible, but in addition I have hearing loss from my 25 years on tanks. Here is the problem I need advice for. Going down the highway I can’t hear my music. I have the Bose with the sub. I went to several reputable shops and they were quoting $5,000+++. Has anyone put a 5 channel amp? If so did it work, what brand and how much?
thanks
Fritz
thanks
Fritz
thanks
Fritz
thanks
Fritz
Bayshore Vette (07-25-2023)
I have for less than $2K of brand name equipment. I did the work myself, so saved on that front. I have also built up systems did several other vette owners. PM me and I can help, or look through the audio/electronics sub forum.
Fteich (07-19-2023)
Received 2,054 Likes
St. Jude Donor '13
I too use hearing aids, for me the big problem is the extraneous noise in the car- tires, engine, wind, etc.
Have you experimented with the balance and tone controls in your car? Helps, some, for me.
Can you get a ride in a really quiet car, to see how it compares?
If I had the choice of a $5k new sound system, or $5k of sound insulation, I'd take the insulation.
Of course, your situation may be different.
Good luck!
Good luck!
Fteich (07-20-2023)
Had the same problem until I had the "Crazy Cowboy" add sound proofing. Sells a kit with instructions that would be easy for an upholstery guy to install. Search this site for him. Made listening to the radio easier after the install.
Fteich (07-20-2023)
Have you considered upgrading your hearing aids. I also have hearing loss not as much as you mentioned you have, I also have a 2017 GS but a coupe . My targa top is off 85% of the time. About a year ago I got a pair of Starkley EvolvAi 2000 that are Bluetooth and connect great with my iPhone . I use my iPhone music library or music apps to hear most of my music via iPhone and hearing aids. When driving my GS I use a Bluetooth device to connect iPhone with CarPlay instead of using lightning cable to connect iPhone with CarPlay. You can connect which ever way you like. As I use the cable way in my GMC Sierra and have no problem hearing music with windows down and sun roof open. When driving the GS I have no problem hearing music from radio. I’m just wondering if you might be better spending money on newer upgrade hearing devices and possibly helping with every day hearing and might help out with you car driving and music experience.
You mention your hearing aids are not good so thinking it might be good to have a conversation with your audiologist about problem hearing music when driving and see if upgrading your hearing devices would / could help out situation.
Fteich (07-20-2023)
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
I agree that the problem may not lie in your sound system.
Not sure how much louder a new aftermarket sound system is going to get considering the factory unit is pretty darn loud and thumpy if you crank it up.
I would have someone with good hearing ride with you and give you an opinion on how the system sounds.
Maybe Verts are different, but my 2LT coupe has a great sound system that is plenty loud at any highway speed with NPPs in Sport Mode.
The following 2 users liked this post by corvettezman:
Bayshore Vette (07-25-2023),
Fteich (07-20-2023)
The man never said that the system didn't sound good. He said he had hearing loss and can't hear it. Don't you think he's already tried turning the volume up? He needs it louder with the top down and the only way to do that is adding an amplifier and speakers to handle/match the amplifier. Adding dynamat will aid in sound quality and clarity but will not aid in overall volume.
Fteich (07-20-2023)
thanks
Fritz
thanks
Fritz
I find hearing aids and wind noise to be generally incompatible. There are some hearing aid models which filter out the wind better than others.
My hearing loss isn't profound, so I use open-canal Jabra's (rebranded Resounds') from Costco ($2k) but tend to turn them off if I don't have a passenger, or put them into 'wind mode' if I do.
I don't try to listen to the radio with the roof off, it's a lesson in frustration.
The other issue is that nearly all hearing aids are designed to amplify speech, not music, and thus music via HA"s sounds like crap. At least that's my experience, so I don't even bother (but I do enjoy podcasts).
Since your hearing loss is significant, do you have solid plugs to prevent sound from escaping? Perhaps you can upgrade your aids to be BT-compatible and thus a) block outside noise and b) send phone sounds direct to your skull? Obviously own't work if you have a passenger, but worth considering.
When motorcycling I have a similar environment (high wind noise, want audio input) and use these: https://earinc.com/product/iplugz-pr...orts-monitors/
Sound like you need to have this kit installed. For about $1000, you can make nearly all of the outside noise go away. My buddy has it, and it's night and day difference in the road noise. I'm getting it for mine too.
https://www.exoticvette.com/the_best...corvette_.html
Received 8,956 Likes
thanks
Fritz
thanks
Fritz
If you haven't done so yet, I would suggest using the Engine Sound Management settings accessed through the center console display to set the exhaust in Stealth Mode when on the highway.
Most hearing aids that have been sold over the last 10 years have a programmable frequency response that helps reduce background noise. I would suggest talking to your hearing aid supplier to see if they can provide a program for your hearing aids that will reduce background noise so you can hear the radio better when the tires are making noise. I know my Widex Hearing Aids have a Party setting that greatly reduces background noises and helps me hear my HPDE students when I am riding in their cars at speeds well over 100 mph with wind noise and wide open throttle loud exhaust noises.
Bill
St. Jude Donor '13
I have a Z06 Coupe and know that with the exhaust set in track mode and with the stock tires it becomes impossible to hear the radio at highway speeds with the windows closed and the AC on. I also have hearing loss and wear hearing aids. If I put the exhaust in Stealth Mode then I can generally hear the music from the radio over the tire noise depending on what type of road surface the vehicle is on. There are certain pavement surfaces where the tire noise is so loud I still can't hear the radio.
Bill
Bill
That's interesting. My Widex aids (less than 2 years old) have a Party setting also, but the audiologist says that setting merely reduces background noise that's coming from one side only. If the noise is coming from both sides at the same time, the setting does nothing. I've tried it multiple times in noisy areas and don't think it does anything at all.
The other thing my audiologist told me was to turn down the volume when there is a lot of wind noise.
Bill
I think I'd look into some type of bluetooth ear buds and forget Tx regs. I bet there are some flesh colored so not noticeable to an officer. I can't imagine your driving around w/ a huge amp putting out music volume that is greater than stock. I realize you said highway but, you get off the highway at some point, and then you would be one of those who thinks everyone w/in 3 car lengths likes the same music that you do.
St. Jude Donor '13
Check your smartphone when you set them to Party. You should be able to go to the equalizer and choose a frequency response that helps you hear better in various situations. I believe there are 4 pre-set choices plus you can make your own custom response and save it. I also have a newer version of the tulip ear pieces that help reduce noise that is bypassing the hearing aids and coming directly into the ear.
Bill
Bill
