Exhaust note at startup
Received 8,954 Likes
No. However, if you have an M7 and never use Eco Mode you won't notice much difference between having the fuse out and having the fuse in with the exhaust set in track mode. As I said in my other post, with an M7 with the Drive Mode set in Tour, Sport or Track and with Engine Sound Management set to Track Mode the only time the valves will close will be when the transmission is in 5th gear with engine rpm below 1500 or less than about 37 mph. In any other gear below 1500 rpm the Exhaust valves are open. That way you can use the features of your car to put the Exhaust in Stealth Mode if you are driving on a highway and want to listen to the radio. My Z's exhaust drowns out the radio when I have the transmission in 7th gear with the cruise set at 80 mph unless I put the exhaust in Tour or Stealth Mode.
Bill
Bill
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,830 Likes
2015 C7 of the Year Finalist
The M2W is simply removing/inserting the fuse for you remotely. I push the right visor button and close the NPP valves. I push the left button and open the NPP valves. THe center button opens/closes the garage door.
Elmer
Casper001 (06-23-2023)
Rafo_Z51 (06-22-2023)
Got it, I misunderstood, I thought you meant that if I pulled the NPP fuse it would give me a code for the AFM. Thanks for the clarification!
The aggressive Cold Start mode that you love so much is the reason for the mean sound on startup that fades away. It is programmed into the ECU. What happens is the ECU pulls timing into the negatives so that the combustion process happens as late as possible and sends more heat out of the exhaust valve to light off the catalytic converters quicker. This is mandatory for all cars by the Government. You just don't hear it as much on regular cars because they are designed to be quiet.
So your valves are not closing after startup, they are staying in whatever mode the car is in. But the timing is being pushed back up into normal values a few seconds after the cold start. Same reason why you don't get a mean startup once the car is already warmed up. Like if you run into the store and come back out in 5 minutes and start the car, you don't get an aggressive startup. It's all based on estimated catalyst temperatures and coolant temps. In some older versions of HPTuners, you can change the cold start mode to either never enable, or to even enable when the car is already warm.
But not as easily or quickly as the M2W allows you to do it. I press one button on my HomeLink to make my system loud, one button to make it quiet. I don't have to go through a series of buttons on the infotainment screen to make the change.
#35
Dave
#38
Leroyt10 (06-27-2023)
#40
