Buying Advice
Buying Advice
Would you buy a a 14 C7 that that looked mint but was driven only 2800 miles, and was in a climate controlled garage under a car cover? Oil was changed only twice in 9 years.
What do you think?
What do you think?
Sure, why not? As long as the price was reasonable and it was equipped the way you’d like and was an acceptable color/ interior combo. I think that would be quite a find! Would probably need to get some new tires on it though. And check some hoses, belts etc. And lastly, perhaps some fresh fluids.
The following 3 users liked this post by Squeaky Wheel:
Moderator
As long as they don't price it as if were brand new because of the super low miles. It's been sitting, neglected, for a long time. Why didn't you mention the price? How can we give you advice on a car of which we don't know the price?
CorvetteMike2024 (06-19-2023)
The following 8 users liked this post by Keith.T:
94Green (06-20-2023),
Artarmy (06-21-2023),
CorvetteMike2024 (06-19-2023),
jlbruggeman (06-20-2023),
meme (06-20-2023),
and 3 others liked this post.
Received 19,439 Likes
'20-'21-'22-'23-'24
The following 2 users liked this post by Vetteman Jack:
MY04CE (06-20-2023),
Vette Jockey (06-19-2023)
Absolutely, it would be worth a look.
It's been used very little for nine years, now rolling into ten, but that does mean anything would be dramatically wrong with it mechanically. I believe the tires and battery would need to be changed. Then you can look at the condition of the fuel system and perhaps check the condition of the other fluids.
But I believe overall, you'd be looking a very healthy C7.
In the end, even though the miles are low, there has still been nine years, going on ten years depreciation. You can pay extra money for the car being in a pristine state, but the owner can't wipe away all of the depreciation. That's just the nature of the beast.
If you make the purchase, please post photos.
Best of luck.
Best of luck.
The following 2 users liked this post by 76-Vetteman:
CorvetteMike2024 (06-20-2023),
Maxpowers (06-20-2023)
Received 8,958 Likes
Changing the oil twice in 9 years indicates the car was neglected. The standard oil change requirement for the C7 is to change the oil at least once per year at a minimum. It is hard to determine if old oil has or has not damaged engine components such as bearings. A check by a Corvette expert won't be able to tell you much in that regard. They are going to see the same things you see.
Bill
Bill
The following 2 users liked this post by Bill Dearborn:
TxLefty (06-20-2023),
Question. What exactly do you want this car to do? I wouldn't go older than a 16 with 2LT trim because I want the electronics. Later on, there were other non mechanical things that they had which I don't care about. I also don't plan to wax the car and it is to be daily driven from April to November whether it rains or shines. Do I care to pay for a 2800 mile car? No. OTOH, if you want a car that hasn't been used much and don't plan to drive much, that is one story. I won't pay the premium such a car demands but I plan to rack up miles. So, even a 16 2LT trim with 2800 miles will cost more than a 20K car. Equal money, I will take the 2800 mile car regardless of color. OTOH, if I want to keep it in the garage under wraps and sneak a peek here and there, I will pay more. What are you about?
Hm... I'd be concerned about all the plastics and seals getting old and brittle. While the lack of heat cycles would be a plus, the lack of circulating fluids would be a concern. You're also buying something that hasn't had a chance to get through the "new car" pains covered under warranty.
I'd much prefer something that was driven frequently to sort out the issues while under warranty, and then continued to driven occasionally just to keep things 'fresh'. Storage is generally not kind to vehicles.
Add new tires to the cost too
I would certainly consider it but the oil only being changed twice in 9 years would be a bit of a concern. And of course a lot depends on the price.
Bill
Bill
My brother just bought a car like that-Owner, a member of our club, passed away 7 years ago-Yes, it sat, oil looked new, he drove it 530 miles home and got an indicated 32mpg. The guy had other Corvettes, the widow decided to finally sell them. It will be a great car, and was priced right.
Not my car, but my brother drives a Mercedes-Benz turbodiesel sedan where the oil and filter hasn't been changed in 9-years. I know, because I owned the car from new and changed oil and filter last.
It's still running fine. Not everyone changes oil at the 1-year mark.
Not advocating it - just relating others experiences.....
Is that meaningful? It might be running but you might shorten the life.
