Is my car possessed? Beeps on its own when parked!
Received 4,736 Likes
Is your car named Christine?
I’ll give that a try.
I think I need to get the battery checked. I have no idea how old it is or if it’s the original. I have said that I hear the noise when the charger is attached and when it isn’t. I suppose it may be making the noise while the chargers orange light is flickering meaning it’s working on getting the battery back to full charge. The car has always started fine but today it seems that batteries work great until don’t……and then you’re stuck. I miss the days of the sluggish start letting you know there’s an issue. This seem like the the first thing I should cross off the list.
Jeff
Jeff
Usually it only beeps if you leave the remote in the car and shut the door so I would take the cables off the battery then wait for about 5 minutes and put them back on
Do you happen to have a curb alert installed? Mine does and whenever I walk in front of it or if parked too close to an object it will emit a low beep when the car is off.
Here is something no one has mentioned. Has your C7 been parked near any Italian cars, or spent time with them without a good mask? We own an Italian car, and have had a few others - ALL of them beep at absolutely everything.
Sorry to poke a little fun at the issue, I'm sure it's bugging you. Since it's a '15, if it has the original battery I would replace it as a matter of course. I know lots of people get more years out of a battery, but you're on borrowed time anyway in my experience. Have you put a volt meter on it? Could be that the battery is not it's normal +/- 13.6v and that could cause some funny stuff to happen.
Best, Paul
Best, Paul
Jeff
Jeff
I looked into a couple of the possibilities brought up here.
I tried to start the car without getting my keys. The car realized that there was no key and wouldn’t do anything.
No idea if the car has a curb alert. I sort of doubt it. Shortly after getting the car I went to back out of a parking place not realizing that I had accidentally put the car in 6th. It didn’t register that the backup camera didn’t come on. Might be because this is the first car I’ve owned with a backup camera. Anyways, I got no confirmation that I was a moron as I scraped the curb so I doubt it has a curb alert.😂
I checked for codes and two codes did come up even though there was no light on the dash. One I thought was funny… “Human - machine interface module code B127E” which also said something about a screen or a plug for a screen. No idea what this is and I certainly haven’t noticed any problem with any of the screens in the car. The second code was P26C5 which came up because I have removed that fuse controlling the exhaust cutout. I found it annoying as to when it decided to open and close so that’s gone.
I ended up buying a battery tester and the battery tested out fine. I then decided to remove the battery since I couldn’t locate the date code. Turns out it is the original 2015 AC Delco battery. Here I have to apologize to my ‘65 in my signature as I thought that battery was ridiculous to get out. The battery in my ‘65 decided to die at a car show shortly after I got the car. Had to use the jack to lift the car and beat on the knock off hub which I had never done before to get the tire off. It’s quite stressful beating on your stupidly expensive newly acquired car with a hammer even if it is lead. Somehow I managed to not hit the fender. Then I had to remove part of the inner fender to get the battery out. I think that was a breeze compared to this one. Just getting the carpet out of the way while not tearing it is a challenge. Then you have to pretty much disconnect everything to get enough room to grab the battery which is double tough without some sort of handle. Geeez!😬. I will probably replace the battery soon but I’m having a hard time identifying that as the problem. The car has always started like a champ whether on or not on the trickle charger. I’d kinda like to go AGM but a video from C&S Corvette said they don’t do well in the heat and I’m in South Carolina.
Regarding the comment about my trickle chargers yellow light flickering. After I read that comment I went out and checked the charger and it was on solid green. I though that was great. The next day when I went to move the car to my workshop garage the yellow light was flickering again. What I did was push the plug harder into that power port in the hatch area and the yellow light went solid. So now I’m wondering if there’s a problem with that port of the plug itself. I’m having a hard time with that causing my noise but who knows. Maybe the inconsistent power is messing up some computer in the car though I pretty sure I’ve heard the noise when the car wasn’t on the charger. I’m going to keep a closer eye on that though.
As far as Italian cars goes………no. Matter of fact, my last car was a Porsche which I loved but the potential mechanical problems along with the related costs scared me. I figured this time I go with something simple with a push rod V8 that a monkey (me) can understand. I hadn’t counted on the AFM issue though. I guess all cars have their Achilles heels.🤔
I guess that’s it for now. The car is now due for its first oil change since I got it. It’s only got around 16k miles on the odometer. I’m still a little puzzled on how to get the car in the air so that should be interesting. What could go wrong?🤔😂
Jeff
Jeff
Leroyt10 (07-27-2023)
So I went down this morning to check on the charger. Sure enough the yellow light is flickering to beat the band. Opened the hatch and as soon as my finger lightly touched the plug the charger goes to a solid yellow light. Seems like it’s slightly losing contact between the plug and the socket. Is it normal for the charger to go back and forth between solid yellow and solid green as it maintains the charge?
Jeff
Jeff
