Ticking noise from passenger rear
Definitely worth a try. I got a new nut on order anyway. I'll give that a shot a report back.
Received 5,597 Likes
It’s a good idea. There is always a tolerance +/-. Go for 190 and see if it changes at all.
Agreed. It's just so annoying, especially with the weather being warmer now and doing more driving with the windows down to keep hearing all the ticking, makes the car feel so cheap.
Update: Tried all the suggestions in this thread, including overtightening the axle nut, replaced that axle nut with a new one torqued to spec and checked all lug nuts torqued to spec. Ended up swapping the passenger side wheel/tire with the driver side and the ticking noise also switched sides. That would seem to rule out the axle/axle nut/hub/rotor and narrow down the culprit to the wheel itself, right? Any ideas why a wheel would make a ticking noise like that? It was visually inspected for cracks as I understand these wheels (OEM Grand Sport Cup Wheels) are known for but couldn't find anything obvious to the naked eye.
I'll check that again but it is not speed dependent nor related to wheel position. It does not tick once per wheel rotation. It almost seems like it is more related to load, like when I put it into gear either D or R, then lift off the brake, during that initial roll from a dead stop and the torque loads up on the wheel, there's a couple ticks. Once torque is loaded on that wheel, the ticks are gone. Until you brake and come to a stop, then it repeats. However, if I keep rolling and never stop, the ticking never returns. Might be a dumb question but is it possible that the wheel itself is shifting a bit in relation to the brake rotor? Like if there was some give between the two and they weren't rotating in sync, does that make any sense? For the record, I have the lug nuts torqued to spec but I am using aftermarket McGard lug nuts. Thanks for the input!
Received 1,300 Likes
I can't see the wheel moving on the studs if lug nuts are properly torqued and you have cleaned the mating surfaces. The stock GS wheels are one piece so nothing there to move. I don't know if the rotors are one piece or 2 - but the noise moved with the wheel / tire so likely not the brakes, wheel bearing, or axle...
If you were drag racing it might be possible that the tire is slipping on the wheel, but you aren't doing that. You would probably also notice an out of balance condition.
Just for grins - have you checked that the nut on the TPMS sensor is tight? Don't think this will click, but just for completeness. I guess you could also check that the balance weights are stuck on tight too...
GL
Ron
GL
Ron
GL
Ron
GL
Ron
Grease does not seem like a good thing on the mating surface of the wheel / brake rotor. You are counting on the friction between the mating surfaces to keep the rotating surfaces from slipping. The wheel studs / lug nuts provide a clamping force that forces the mating surfaces together to generate the friction force. The wheel studs really aren't designed to resist wheel rotation through shear forces on the studs.
Ron
Ron
Gearhead Jim (05-23-2023)
Ron
Ron
