Injector cleaner
Injector cleaner
Anyone run any kind of fuel injection cleaner like Sea Foam or….? How often should the injectors or fuel systems in general be cleaned/serviced?
Popular Reply
02-20-2023, 11:28 AM
Received 19,441 Likes
'20-'21-'22-'23-'24
I run a bottle of Techron Concentrate 1-2 times a year in my car.
'20-'21-'22-'23-'24
The following 9 users liked this post by Vetteman Jack:
Bills17n72 (02-22-2023),
Diamonddave60 (02-21-2023),
Gixxerman (02-20-2023),
hanks10GS (02-20-2023),
jimmbbo (02-21-2023),
and 4 others liked this post.
Moderator
Received 3,763 Likes
St. Jude Donor '18-'19-'20-'21-'22-'23
I use Techron a couple times a year as well.. good stuff
Vette Jockey (02-21-2023)
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,832 Likes
2015 C7 of the Year Finalist
I use a gasoline that has injector cleaner in the gas. I've never had an injector plug up since I've been driving FI cars. I just don't see how those injector cleaner manufacturers have been able to stay in business without me using their products.
Elmer
Elmer
The following 2 users liked this post by eboggs_jkvl:
StrykerZ06 (02-22-2023),
Your owner's manual recommends using Delco Fuel System Cleaner (re-labeled Techron) once a year, unless you're using Top Tier gas regularly.
If you are NOT being facetious, the answer is simple. Cheap snake oil and people will say "What have I got to lose?" so they buy it. If they feel a difference, they will be back. If not, there are more suckers down the line.They don't have to make a ton of money off each one. Easier to milk the suckers by volume, of which there are plenty.
Thanks for all the responses. I don’t expect to feel or hear a difference. The goal is to keep them clean regularly so there is no difference. I normally use a “top tier” fuel but I’m sure there will be times when the first station I see gets my business. I will throw some Techron down the pipe once or so a year. At worst it probably does no harm, at best it does what it promises.
another vote for Techron , plan to do it once a year prior to oil change
I mostly use shell 93, still use it for maintenance purposes.
I bought a few Chevron Techron Concentrate Plus, 10 oz bottles, i need to recheck my supply.
appears the price like everything else went up drastically to double what I paid 2 years ago.
MyDarkAngel (02-21-2023)
I just run Top Tier gas (Costco).
I have never tried it on these injectors yet so I don't know. The Bosch style injectors do pick up some varnish that I can see. I have gotten the before and after results from FIC which I verified on an actual injector bench. There was some build up that got cleaned by FIC and others like them. Also it gets the basket filter changed
Nope, I don't believe I need the techron to keep my injectors clean.
Elmer
I don't know yet. I know my L98 style injectors pick up varnish based on the before flow numbers compared with the after cleaning flow numbers. I will test the GDI injectors and see when the time comes. At this point, I will know, not believe or guess.
Moderator
I am required to have a use for little plastic funnel once a year to keep plastic in good condition and properly justify it's position in my Corvette's cubby compartment.
Catfish4818 (02-21-2023)
The following 5 users liked this post by aklim:
Catfish4818 (02-21-2023),
Gearhead Jim (02-23-2023),
Gixxerman (02-22-2023),
joemessman (02-22-2023),
joghotrod (02-22-2023)
