I bent my GS
I bent my GS
Oh man. I’ve jacked up my 19 GS a number of times. I never bothered to open the doors. I noticed recently that my pass side door is rubbing against the fender just slightly when opening or closing it. It’s knocked off tiny spot of paint. It’s at the lower part of the door. Has anyone else done this?
Sounds like a rock chip. A pic or video would help. If it's truly the door rubbing, then that usually indicates someone on the large side uses or has used the open door to hold onto when standing up. Worst case....adjust the door or have a body shop adjust it for proper fit.
The following 4 users liked this post by 96GS#007:
BAT (02-12-2023),
CorvetteMike2024 (02-12-2023),
Crossed Flags Fan (02-13-2023),
jwmgr8 (02-12-2023)
Moderator
I read somewhere (from Jim Mero?) that the C7 frame is 10 times stiffer than the C6. There is no way jacking could do this. You'd have to seriously wreck the car to bend it. The opening doors thing is from much older, much less stiff cars. Your issue is probably a body panel/door alignment issue from the factory that is surfacing now.
96GS#007 (02-12-2023)
Definitely body panel alignment if you see it rubbing.
Moderator
Received 3,763 Likes
St. Jude Donor '18-'19-'20-'21-'22-'23
Remember that bottom panel is glued to the car..
Received 8,958 Likes
Bill
Notover (02-12-2023)
Check gaps on door fit front and rear fender if more at the top of front and less at top of rear adjust door fit and check hardware for wear. Using proper jack points should not affect frame.
Received 19,435 Likes
'20-'21-'22-'23-'24
Received 4,742 Likes
I had the left door rubbing the fender when I picked my 19 GS from the dealer and it was new!! There was no paint rubbed off yet and the body shop adjusted the fender. 4 1/2 years later and no issues. The fender was misaligned from the assembly plant.
Bayshore Vette (02-13-2023)
https://www.corvetteforum.com/forums...-question.html
69 L46 4 Speed (02-14-2023)
