Body damage from road hazard, how bad?
Cruising
Hello friends,
A nearby car kicked up something hard at highway speed and it punched a half inch hole in the fiberboard (don’t know the technical term) right ahead of the driver side rear wheel well.
Any idea how bad/hard this will be to repair?
Thinking to the future, I’m going to buy running boards, or side skirts, whatever. My autobody vocabulary is not great.
Thank you
Matt
Thank you
Matt
Anything you buy or fix on these cars you pay a "corvette tax "!! With that said I think it will be at least $1500 or more .
Best “fix” could be to add the Z06/GS style rear brake ducts to the area if you like that look. Should cover the area well. Otherwise a shop can patch the area and paint well enough to blend in.
The following 2 users liked this post by Buddhaman:
15 Z51 conv (12-30-2022),
Shirl (12-31-2022)
St. Jude Donor '06-'07-'10, '15. '22-'23
I had someone in front of me kick up a rock on the freeway that put a hole in my lower bumper about the same size. I had it filled and painted for around $1500 or so. It looked fine after that, you couldn't tell there was a hole before.
Good body shop will have no problem with it and the way you described the event it will be covered as a comprehensive loss (not at fault) loss by an insurance company.
miami08VETTE (12-30-2022)
Received 8,958 Likes
Hello friends,
Thank you
Matt
Thank you
Matt
That damage is on what GM calls the aperture panel that wraps completely around the door. You don't want to replace the aperture panel as it involves a lot more work. The proper way to repair is to sand, fill, finish sand and paint match.
Bill
What, nobody has said "That will polish out" yet? Seriously, have a good body shop check it out.
It is unclear if side skirts would have prevented that damage but they're a good idea, anyway. I have no nicks or other damage on the side of my car with the OEM Grand Sport side skirts. A big difference to my C5 which sand-blasted the panels behind the wheels.
I think I would put on the side brake ducts. Get your insurance company to cut you a check for the damage and apply it to the duct kit. Problem solved and you get an upgrade!
OUCH! Sorry this happened to you, hope you get it all sorted out. I had something similar happen to me,(not as bad) but my PPF took most of the hit. Good luck and I have no idea how much.
Received 19,427 Likes
'20-'21-'22-'23-'24
That was one heck of a hit - a good body shop should be able to patch the damage and make it look like new. Best of luck with the repair.
Received 4,740 Likes
Kangarew (01-01-2023)
2023 C7 of the Year Winner - Unmodified
I had a similar experience, but the Expel film prevented any damage to the car. Had the film replaced for $50.00. OP's hit was a thousand times more severe. I was clipped by an unattentive driver at a 4th of July parade. Just got it back a few days ago. Peeled my rear bumper back on my 2019 GS. Entire rear bumper had to be replaced at a cost of $4,600.00. Took six months to have it completed (backorder on parts, paint curing before stripes applied, etc.). Thought it would never get finished. Negotiating now with other guy's insurance company on diminished value. Wonder how long that will take.
