Overheating issue on my 2016 stingray
3rd Gear
Hello Ladies and Gentlemen. I am new to this forum or any forum for that matter. Hoping someone can help me. I have a 2016 Stingray that I’m having an issue with it overheating when I drive aggressively. It doesn’t overheat when I’m driving at high rate of speed, as long as I don’t gun it and get to a high speed right of way. I can let the car sit in 100 degree weather and it will not go Over 205/210 degrees, I can drive in traffic with no issues whatsoever except when I put my foot on the pedal and gun it is the only time it will overheat. I have replaced the thermostat, had radiator flushed and rodded, mechanic said it wasn’t even dirty. The only thing I can think of is my water pump is going bad, but show no signs of it , fans run fine at idle and while running. Again only happens when I floor the gas pedal. Would anyone happen to have had a similar issue and found the problem. Thanks in advance, brother for any feed back and allowing me to join the cyber corvette nation .
Sincerely
Eric
Sincerely
Eric
Received 8,958 Likes
What temperature do you consider to be overheating? You haven't mentioned any temperatures that indicate the car is overheating. The fan should cut off once the speed goes above 35 mph. If it doesn't it might cause overheating due to restricting airflow.
Bill
Bill
Received 4,742 Likes
Welcome to the forum! What are the temperatures when you say the car "overheats"?
3rd Gear
Bill hello, it runs fine and stays at 210 all the time no matter if I’m driving or sitting at idle the temperature will only go up to 250 if I stay on it, it will max out. I noticed I was overheating so I let off of it. I’ve never had this issue before and haven’t done any mods to it either. First thing I did was change out thermostat, that didn’t work. Took car to shop so the flushed and rodded the radiator. Tech said it was in perfect condition. No built up sludge and antifreeze was clean. Bill, this only happens when I floor it. By the time I hit 80 or 90 temperature is already going from 210 to 230,40,50in a matter of seconds. As soon as I let off throttle it slowly comes back down to 210.
210 is normal-ish for a Stingray, 250 isn't.
Sounds like a bad water pump for sure, especially since it's only when you're gunning it and it's directly driven by the belt. They can go bad without making noise/leaking. Maybe it is leaking somewhere but it's hard to see. The only other thing I can think of is a massive air pocket in your cooling system but that would've cleared up from the flush and re-fill.
All C7s have had really random overheating issues across the entire generation, fans dying intermittently, thermostats stuck, water pumps going bad, manufacturing defects, you name it. It's random and uncommon but it happens.
Good luck.
Good luck.
Get the thermostat tessted also as 180 is normal.
Have you checked the coolant level - if not, that might be the issue. Corvettes are not always filled to the Upper limit when leaving the factory.
3rd Gear
STrMo , 3rdgear, thanks. Thats the only thing I have left to do other than replacing the fans. But fans sound strong. I was thinking about replacing the water pump to a high volume water pump since my warranty ran out I’ve been wanting to put a supercharger in it. I finally settled on a bolt on Paxton supercharger. So I’m gonna need the extra water cooling to cool that engine down. Guys this is so cool, having someone I can count on for advice. I’ve never been a part of any forum what so ever. It’s a brotherhood and sisterhood . Thanks to all of you for allowing me to be a part of this community and for all the advice. You guys have an awesome day/afternoon.
If you are not the original owner, it is possible that someone put an aftermarket thermostat in your engine. I bought a 180* thermostat to replace the 195* stock thermostat. It worked great for about nine months. Then started doing the exact thing you described. It was running much hotter than it had been, The temp was always around 200-210 and would climb higher when you got on it. I put the stock thermostat back in and the problem went away. However the engine was running hotter than I'd like, so I am on my second aftermarket thermostat.
Lyle at C&S Corvettes has a great video on overheating. He shows the radiator covered in dead leaves. Subscribe to his YouTube channel and check it out.
Don't know if this would matter much but the manual calls for a 60/40 ratio coolant/water. I had my cooling system flushed and refilled recently and noticed my 2017 manual coupe was running about 10 degrees hotter than I was previously used to seeing. Checked with the shop that did the flush and found they had installed 50/50 Dexcool mix. Guess that could make a difference if you're running 50/50.
See if this link works for you.
https://www.reddit.com/user/wadenels...dy_diagnosing/
Diagnosis of overheating ALWAYS begins with pressure testing the cooling system. Always.
I know just how excruciating owning a sport/lux car that overheats is. Always staring at the temp gauge when you should be having fun. Like
when I was in Santa Barbara (40 years ago), and a convertible full of co-eds pulled up next to me at the light, commenting on my ride, and all I could look at was the temperature gauge on my XKE, wondering which would happen first, the gauge move into the red, or the light turn green.
After you've read this document, pressure tested your system, etc. I'd be glad to answer any ?'s you might have.
Let's get you back on the road having fun.
Hi Eric, sorry for your problem. Here's my 2-cents.
I don't think it is thermostat related. Warms up fine, doesn't overheat under normal conditions.
I am thinking it is FAN related or air flow.
I believe the AC is shut-off during acceleration. In turn may be shutting off the fans. Fans are ON with the AC unit ON.
Check water hoses if they are squeezed or kinked.
Is anything changed under the hood or front end? After-market air cleaner, chrome covers, ..... Something changing air-flow!
Is anything blocking air intake to the front grille? License plate, after-market spoiler sucking air under the car, ....
Is the car 'Tuned', non-factory? After-market throttle-body or exhaust?
Are all rubber gaskets in place and good shape under the hood? ( good air flow )
Does it make any difference if the AC is On or Off?
Well it go to 250 even when driving over 50mph on highways. (high air flow) Is it only during city driving? ( low air flow )
Sorry for so many questions but questions lead to answers.
Good luck,
Ron
Good luck,
Ron
Before ripping into it and shooting the parts cannon at it check the obvoius first , Bad thermostat can stick in the half way open position , Cheap to buy ,easy to replace and easy to check with a pot of hot water and a cooking thermometer
Don't replace the fans without checking with someone who has GDS2 , GDS2 can log when your fans are coming on and off and at what speed
Dave
Dave
The only lower temp aftermarket thermostat that will not fail is the Katech, they use an OEM body . They come in several temps and are expensive but expensive is a relative term when all the others fail ...
Dave
