Steering wheel question
Will a manual steering wheel work on an auto car? If so I was going to change out the rev match and add my paddle shift off of my wheel. I know it may be a long shot. Thanks!
Received 19,361 Likes
'20-'21-'22-'23-'24
Interested also.
Other the the decal on the paddle shifter they function the same
Yep, the same wheel.
same wheel and foot print on the paddles. You'll find the main Torx Nut a Bear to break loose, best to get another set of hands to stabilize the wheel.
Be sure to get a HIGH QUALITY T50 torx bit, (SnapOn recommended) as if you don't you will most likely stripe bit and bolt, quickly turning it into a difficult project. Be warned: These bolts are often in extremely tight, sometimes not.
Many recommend using a soldering iron to heat up the bolt first. It helps loosen the thread lock.
Kevin A Jones (03-01-2022)
