info icon is stuck and gas mileage wrong on full tank
Hello, I have the i stuck on all my displays and my gas mileage when full tank shows less than 200 miles it use to say 300 miles ?????
Received 19,429 Likes
'20-'21-'22-'23-'24
Try disconnecting the battery for about 20-30 minutes and see if that will reset things. Could just be a glitch in the system. If that does not work, a trip to the dealer may be in order.
Perhaps the "Happy Foot" was working overtime on the prior tank of fuel??? The computer uses the milage from the prior tank to extrapolate how many miles you can expect from the next fuel load. It should even itself out once you even out your driving habits.
