4-Post Lift - AMP Question
Hey Guys,
I'm about to pull the trigger on a 4 post lift for lifting (2) C7's. The directions say I need a 110v 20 amp outlet...but the vendor is saying to up it to 30 amp? Can anyone tell me what is truly necessary for operating the lift? Is is easy to change my 20 amp outlet to a 30 amp? This outlet will not be shared or used by anything but the lift.
Thanks!
Thanks!
Should be easy to change the breaker in the box. Electrician would be best if you aren’t comfortable but it’s like changing a fuse.
Mayor111 (02-18-2022)
Received 8,961 Likes
How much current does the pump motor draw, especially when It is turned on? The vendor may have sufficient experience with the pump motor current draw and problems other people have had to know you really don't want to use a 20 amp circuit. You don't want to be raising the lift, let off the up button, then decide the lift has to go up a little more, hit the up button again, and blow the breaker.
As for the cost it depends on how your house is wired. A 20 amp circuit can be wired on 10 or 12 gauge wire. Most people will probably use 12 gauge to save money, and because it is easier to work with. A 30 amp circuit needs 10 gauge wire. If your house is wired with 12 gauge I imagine an electrician will just add a new circuit with 10 gauge wire, a 30 amp breaker in the breaker box, and a 30 amp receptacle along with the in-wall electrical box. If the 20 amp circuit is wired with 10 gauge then the changes are a different breaker and a different receptacle.
Talk to a few local electricians to get estimates of how much it will cost to add the circuit.
Bill
Bill
Looking at Lowes, I don't see any standard plug receptacles that are rated for 30 amp. The 30 amp/125 volt rated ones look like electric stove or dryer plugs.
Most these lifts have ability to be wired 110 or 220 with a simple switch of the feed wires. 220 would be simpler unless you are a long way from your electrical panel. Twice the voltage half the amperage.
If you insist on 110 volts then a slow blow or delayed breaker might get you by the initial hit of peak currant. But stay with the size breaker that is sized for the wire
I've had my 4 post plugged into my regular outlet for 12 years...NO ISSUES!!! And has always had a car on top.
It's unlikely you can easily "change your 20 amp outlet to a 30 amp." As others have said, a circuit's load limit is driven by a combination of things including the breaker, wiring, and receptacle ratings. To safely handle a given current draw, ALL the components must be appropriately specified.
The following 2 users liked this post by NortonCO:
Dads2kconvertible (02-18-2022),
Mayor111 (02-19-2022)
I’ll blame my stupidity on being a mechanical engineer and not electrical (even though I focused heavily on circuits in college).
The following 3 users liked this post by Buddhaman:
