Merged battery thread - cost of a new battery
#41
I did. I also tried it with the post strap type,
but it kept slipping off the posts.
The Tong type made lifting out much easier.
#42
So chevy has $188 battery with 24 month where it used to be $149 for 42 months. Die hard has one OEM fit for $199 with 4 year replacement, more CCA and more RA. Will the Die hard still work just as good in the car and with the Corvette trickle charger?
#43
Moderator
Yep they are led acid batteries. The tender works great with any of the ones you listed. What's important is to get the one that matches OEM size and meets or exceeds performance.
#44
DieHard Platinum - Battery, DIN Group Size H6, 730 CCA, 910 CA, 120 RC (Part No. 48H6-RP)
Description
Read 1 review(s)from $199.99
VIEW PRODUCT
#45
Hello, I was thinking of replacing my battery in my 2017 Stingray. I called my Chevrolet Dealership, near Seattle Washington and the price was $200, plus $100 to install, plus around $30 for tax, = $330.00 or so. Seems high to me. Plus the new flat rate is now $179 per hour. Comments?
#46
I just had mine changed yesterday on my 2015 that was built in August 2014 – almost eight years ago. It was still working fine but I thought I might be pressing my luck at this point. I did my research and had my dealer put in a ACDelco Gold series 48HPG (GM p/n: 88865275). Pricey but I had a $25 coupon that helped. My dealer only charges a flat rate of $25 for labor on battery installations. Total cost was a little over $200. GM also has a $10 rebate going on right now but I didn’t like all the unnecessary information they require on their rebate form. So after reading their privacy statement I decided ten bucks isn’t worth giving them all the detailed info they wanted. Check out the ACDelco web site https://parts-catalog.acdelco.com/acesCat.php? Lots of choices.
#47
Art17 (02-12-2022)
#48
$209.00 for the Diehard Platinum @ Advanced Auto Parts. Sales tax was extra.
Art17 (02-12-2022)
#49
I think over $300.00+ at the Chevrolet dealer.
Art17 (02-12-2022)
#50
I saw that website but he said that was the only one he could get. Think I will just get the die hard
Art17 (02-12-2022)
Art17 (02-12-2022)
#52
When you make a thread that concerns a dealer. good or bad, please name the dealer and location so everyone can get the best service available.
This alone would solve a lot of peoples concerns.
Art17 (02-12-2022)
#53
So I am in need of a new battery. Called local dealer and he tells me that they have changed and there are no more 42 month batteries only 24 month. Also the battery is $185.99. I have no problem with the cost but the fact the warranty is short sucks. I want a AC Delco battery but damn. He said only battery they show is a 48GHR.
#54
Moderator
So this one looks like it exceeds the OEM so it should be good?
Description
VIEW PRODUCT
#55
Like I stated earlier in this thread, the Delco 48PG or 48HPG is the Delco battery you want. Dealer may try to tell you it's been superseded to something else but I don't believe it has and since MWAZ purchased one yesterday which proves it's still available. It is a little more expensive as the 48PG or 48HPG is 770CCA/120RC70AH compared to the 48PS 615CCA/110RC/70AH.
I had put in a new battery 1 year ago...similar OEM replacement Delco.
When I hooked up to the CTEK Multi US 4.3, I selected the standard mode. (temp range greater than ~ 49 degrees).
Whoops, with the cold weather in OH over December/January (often down to single digits), I went out to my storage facility to see how it was doing and change the mode to cold weather (handles temps into the negatives).
The battery was completely dead.
Took it out, returned it to the dealer, and got a new battery for no charge.
Reinstalled it, back on the tender in cold weather mode, and so far, everything is doing well.
Glad I got a free replacement.
New battery did not have the integral handles (darn), but I got it swapped in with only a small abrasion.
#58
Save 15% off your online purchase with code DIYSAVE15 FEBRUARY COUPON SAVE 15% On regularly priced items when you use code on your online purchase.
Expires on Sunday 2/20/22
https://shop.advanceautoparts.com/we...0051&langId=-1
#59
Moderator
Kevin A Jones (02-18-2022)
