Valentine 1 gen 2 blend mount bracket
Just purchased a new Valentine 1 Gen 2 radar locator and found that it will nit fit my Gen 1 mount (a bit too wide). Anyone know where I can purchase a Blend Mount bracket for a Gen 2?
I think I have one but won’t be able to check until Sunday.
saleen556 (10-29-2021)
Found it. It’s just attached to a 3m mount.
2020 C6 of the Year Finalist - Modified
If you are referring to the piece in post #5, your V1 Gen 2 should have come with a new one of those. The only thing wider is the bracket and the detector by a couple of hairs. Mine fit perfectly..
If you actually need the blendmount piece here is a discount link.
http://blendmount.refr.cc/troylindekugel
72rdstr (11-14-2021)
Thanks to all that replied. I found that all I needed to do was remove the suction cups on the windshield mount provided by Valentine. The piece then bolts right up to the Blend Mount.
