new vett owner
new vett owner
Hey there, i have a 2015 z51 stingray. looking to see what the widest back tire i can go. I need a lot of guidance lol. Also, does anyone have trouble with shifting into second? Also, is it a huge process to lower a bit?
Received 19,454 Likes
'20-'21-'22-'23-'24
Moved to C7 General.
1-2 shift can be a little stiff especially when cold. I switched to this trans oil and it helped a lot.
by https://www.flickr.com/photos/152454123@N04/, on Flickr
Look for threads here on "lowering using the stock bolts." It is pretty easy to do.
Chomorro (10-26-2021)
Received 2,062 Likes
Why? For road track use? For the appearance that you race road tracks? Certainly not for straight line acceleration, since extra width alone doesn't increase traction.
It is easy to lower.Getting it with zero camber and toe for better tire wear ain't.Even adding a adjustable toe link doesn't get my GS to zero.It's better,not perfect.
Probably just me or the alignment guy? Gonna start a thread and see
Received 4,743 Likes
Raidercop (10-28-2021)
As Dale mentioned lowering on factory bolts is simple. Lotsa threads on this. Congrats on your new ride.
When a car is lowered you will get negative camber. So you will need alignment. A C7 also has a rear caster adjustment and it needs tools to adjust. You will need to find a shop that has the tools that measure rear caster.
Rky Mtn C6 (10-28-2021)
