Cabin Filter
Cabin Filter
I have changed out the engine air filter and the cabin filter. First time for me on this vehicle. I viewed the videos one can find on the internet on 'How To'......they make it look so easy....,it ain't............
After a few banged up knuckles and a few choice words i got the engine filter in.
On the cabin filter The videos show 'arrows' that indicate air direction flow. Well my OEM filter does not show them? The one I took out to replace did not show any either? I looked at the replacement and it looked like there was no difference in material density on either side. So, I just replaced it with the 'printed' info on filter facing up so one could read it, in other words not up side down??
Do you all concur?
Do you all concur?
Received 19,428 Likes
'20-'21-'22-'23-'24
I think you will be fine in terms of the cabin air filter.
And I agree about the engine filter - kind of a pain to get to with the hood lift in the way.
Yep, same problem, no arrows on the OEM filter. Difficult to install without deforming the cheaply made filter. I get a flashlight to be sure the filter is covering the duct leading to the cabin. It seems like when I get an oil change at the dealer they check the cabin filter by removing it and then shoving it back in incorrectly deforming it.
