Manual tranny with NPP, I found an oddity, does yours do this?
Does not matter what mode you are in and how you set it the valves will not stay open 100% of the time as Elk stated you must pull the fuse to accomplish 100% open npp valves.
I have a mild2wild switch, programmed to the buttons on the visor. I leave for work at 5:15am and do the quiet button until I'm out of the neighborhood. After that, I press the loud button and run that the rest of the time. When the loud button is on the valves are open all the time, quiet mode they operate as stock according to the setting you choose.
In the 99,750x miles I put on my MN7 I really can't say I ever noticed.... I just drove the thing....
The valves will not stay open 100% of the time unless the fuse is pulled. There are many situations where the valves will slightly close (cruising , light load and such).
There's damned near always an M7 "bark" from Rev Match irregardless whether your C7 has NPP or not.
Upshifting there is no M7 bark. Upon upshifting an A6 or A8 there a freaking awesome BARK on WOT, which does not happen on MT.
I rarely downshift when slowing. Just put it in neutral and brake if necessary. Shifting into 2nd from neutral as I round a 90° city corner and go on my way. It's gratifying to drive a MT Corvette.
When I shift to neutral.
What you're stating makes more sense, assuming I'm understanding you and that I'm not hearing things while driving my car. In Track mode, when set through the infotainment system, the NPP valves PARTIALLY close when the engine is under light load. In Tour, and Sport modes, the NPP valves FULLY close when the engine is under light load. In Stealth mode, the NPP valves simply do not open (thus the statement in the owners manual about using Stealth mode during track events/competitive driving and damaging the valve actuators). Right?
Get a mild to wild switch to avoid the valves randomly closing. One of the best low cost things I have done to my car.
#33
Close enough to not make no nevermind.
#34
#35
From any other gear than 1st.
The RevMatch synchs in upshifts is where it really 👌 does pay off in engaging at startup. The "bark" I don’t need when going to neutral and coasting - but it's great to have the technological rev matching on up shifts when driving it in normally easy driving.
Even though I don't care to downshift to slow the car. Popping it neutral to me is so much easier and then braking as necessary to slow the car.
#36
Received 8,956 Likes
As for Stealth Mode, the valves do open when the rpm and engine load get to a certain point. Several forum members have found this out when running tracks with sound-level rules. Even in Stealth Mode, the valves opened and they exceeded the track sound limit.
Bill
Skid Row Joe (12-05-2021)
#37
Driven MN cars since '57, autos too.... corner downshift? Pop the paddles down as many as necessary and accomplish the same thing....
#38
Bayshore Vette (12-06-2021)
#39
Bill
