Windshield Residue
Windshield Residue
Help! There is some kind of residue on the inside of my windshield I can’t seem to remove. Not sure if it’s the Adam’s Interior cream paste I accidentally got on it or what? I have tried just about everything I have to remove it but alas it’s still there. There’s got to be something you guys have used before that cleans the glass.
Dundee (06-18-2021)
Residue
Try an ammonia glass cleaner like original Windex (cover the dash, etc with towels). Most glass cleaners contain no ammonia, but sometimes you need the ammonia in order to cut into smudges. If that doesn’t work, try misting with a detailer (I use Maguires) and rubbing with a clay bar, THEN clean with window cleaner to remove clay bits. BTW, you will have to toss the clay bar afterward.
Best of luck & let us know how it goes,
Kangarew
Kangarew
Received 19,415 Likes
'20-'21-'22-'23-'24
If it happens to be something from Adam’s, give them a call and ask for advice. They give very good customer service.
Good suggestions guys, the alcohol didn’t help, paint thinner didn’t help, Windex with ammonia 👎🏻, Krud Cutter 👎🏻, I’ll try a clay bar next.
I’m not sure what the residue is on the glass, my only guess was the Adam’s. Keep the suggestions coming, thanks.
Ruouthere (06-18-2021)
Okay, tried the clay, it didn’t work either. I thinking maybe a well placed rock? 🤔
If you can, take a pic. Totally curious lol.
Try Mr. Clean white pads. It is like 5000 grit and won’t scratch the glass.
I just had a similar problem. Got something on the inside glass and couldn’t get it off.
Turns out the new inspection sticker I got in April appears to have a new adhesive that dissolves.
Wound up smearing my windshield as I cleaned it.
Took me 3 days of using windex and Spray Away glass cleaner and paper towels to get it clear.
The following 2 users liked this post by GREENKAR:
Har-ray (06-18-2021),
yellow2007 (06-18-2021)
The following 3 users liked this post by Maxpowers:
ALL RIGHTLY THEN! The Mr Clean eraser worked, after two freakin days of trying everything I though might remove the residue, the eraser worked.
THANK YOU THANK YOU!!
The following 2 users liked this post by Ruouthere:
joemessman (06-21-2021),
Vette Jockey (06-18-2021)
Roadster Madness. 😠
Received 1,525 Likes
St. Jude Donor '13, '20-'21
I use the "Original".
I had had two black smudges on the passenger door and a re-occurring one by the gas lid opening. I used different methods to try and get rid of them and nothing worked. I remembered several people on the Forum suggesting these pads. I borrowed one from my Wife. I wet the area down and used the pad. They all disappeared with no damage to the car! The one by the gas cover occasionally shows up, I have no idea why, I am very careful at the pump, and I wash the car by hand.
Now, that pad is in the garage.
Be careful, the Magic Erasers are mildly abrasive. They are made of melamine foam.
Received 5,239 Likes
Mequiar's have a glass polish that I like...
