C7 ZO6 under pan deflectors left, right and middle.
Bought a new deflector with center tray for the ZO6 to replace the stage one. Unfortunately there are no provisions to re-attach the center deflector. I assume that Chevrolet deemed it important. Don’t know why ACS says to leave the under pan but it is completely covered and doesn’t seem to be necessary. Any one deal with this problem before? Thanks
joshtried (06-17-2021)
Known guys in here to remove all of them….no indication that it cases the engine to run any hotter….FWIW
The following 2 users liked this post by bbrown450:
joshtried (06-17-2021),
OldDave67c7 (06-17-2021)
St. Jude Donor '08-'09-'10
I can tell you that I have removed them on my base model with no problems. I thought I might experience more of a feel at high speed (like floating or turbulence). I feel nothing. Im sure there is a reason for them... If you want it on, drill some holes. If you dont, you will probably never miss it.
The following 2 users liked this post by joshtried:
LT4CMG (06-17-2021),
I have a GM stage 2 with undertray. The center one is automatically removed. I also removed the outers. Good riddance. Have had plenty of 160+ mph runs. Car sticks like glue without that ugly rubber
Stage 2/3 cars don't use the center piece.
