SOLVED: Underhood charging
Back in 2019 when I bought my ZR1 I posted a thread in that forum section about charging the car via underhood charge points (like BMW builds into their cars). The responses were helpful but more workarounds than factory-designed. Just recently I found online that there ARE designated charge/jump-start points under the C7's hood. Attached are pics of my ZR1 hooked up to my battery tender.
Doesn't the ZR1 already have the convenient built-in charging port in the back like other C7s?
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,832 Likes
2015 C7 of the Year Finalist
That post you "discovered" is true to be a direct connection to the battery BUT it cannot take a real battery charger connected to that spot. It'll do just fine and dandy with the C-tek battery maintainer but that's all the juice you can run at that point to the battery. I have my C-tek hooked up to that point and hook up every time I park it in the garage.
https://www.corvetteforum.com/forums...opped-off.html
Elmer
Elmer
Elmer
Elmer
- No, it's not at all convenient if you want to use a charger with conventional alligator clips. And it's not convenient if the charger you have hardmounted on the ceiling to service multiple vehicles in that particular bay cannot reach the trunk's port. Being able to charge (or jump) a car from the front or rear is convenient.
The following 5 users liked this post by Kevin A Jones:
Boiler_81 (05-01-2021),
Elk (05-01-2021),
flyercatz77 (05-01-2021),
Ttrein76 (05-05-2021),
Vette Jockey (05-01-2021)
Received 19,449 Likes
'20-'21-'22-'23-'24
If it works for you, that’s what matters. I do not have to take into account the other issues you mention when connecting the battery tender to my car.
SouthernSon (05-20-2021)
Moderator
Received 3,763 Likes
St. Jude Donor '18-'19-'20-'21-'22-'23
The following 2 users liked this post by Gixxerman:
Kevin A Jones (05-01-2021),
For the vast majority, this is a solution looking for a problem.
The following 3 users liked this post by Elk:
Received 2,062 Likes
As a recent C7 owner (8 months), do the C7's have the same battery draining issues that the C6 did or are they better or worse?
So far, I've never experienced the problem with either car, but with a couple exceptions they've been driven more than once a week and maybe that's the difference.
I use a magnetic connection to hook my c-tek up on the front. My wires from the magnetic connection go to the post that you show in your picture with the ground lead fastened to a fender ground post. If I forget to disconnect the c-tek, the magnetic connection just parts and the plug simply falls to the ground as I back out and I drive away without issues.
Elmer
Elmer
I guess I could back in to the garage but then I'd have to climb over the console and get out on the passenger side. Did I mention that I am 77 years old? Climb is not a strong word in my vocabulary at my age!
Whippersnappers.....
Elmer
Leroyt10 (05-08-2021)
EASY-PEASY:
Significantly worse.
P.S. I do not have an active OnStar subscription on the C7 ZR1. My C6 ZR1 would go dead in less than a month.
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,106 Likes
Hey now! I use it often. Haven't had a dead battery but I like to keep it nice and fresh. Besides, never run a vehicle for any period of time after jumping a start. Alternators are used to maintain, not deep charge. Every had a voltage regulator go bad?...especially after jumping and driving at night with lights on. May be better now but I won't do it. If ever it is dead I will deep charge with my trusty high output charger before driving and putting a load on it.
