Soler Throttle controller issue
Has anyone had their car tuned with this installed. I had mine tuned this past weekend and during the tuning process the car went into reduced power mode and the screen on the soler went blank. I removed it and the car ran fine and we were able to finish the tune. Can they not be used if you change throttle sensitivity in the tune?
Just my 22 cents............
ANY TIME you are working on your c7 that requires you to disconnect and/or plug in any wiring harnesses, my advice would be that you disconnect the battery first. In my opinion, it doesn't matter how insignificant you may think the wiring connection/harness may be, its just a safe practice to lift the negative connection from the battery.........do the work..........then re-connect the negative connection on the battery. I go as far to lift the negative on the battery & wait 30 min. to start messing with the wiring connections.
Probably overkill...........but......better safe than crying later!
I'd consider installing the TB and the sensor/wiring for the TC and connect the TC unit later
Or program the controller for the OEM throttle response while checking out the impact of the throttle body. Then later play with the controller's settings to find the response curve you like.
They are both great pieces of kit. And Mike's service is unsurpassed.
redman76 (06-29-2021)
Had some questions about the throttle controller so I called and left a VM for Mike. Less than an hour later call and answered all my questions
What a great device that fixes the lazy throttle that can be tailored to suit ones driving style. Best of all it's hardware based and easy to install!
I put a Soler TC in my '19 shortly after getting it and had no issues. I put one in my '16 a couple of days ago and on the initial test ride the CEL came on but no limp mode. Got home, unhooked the battery for 15 min per the instructions and all's well. I tried the Ludicrous setting once, not advisable for street duties.
