I Bent Three Aftermarket Wheels On My '19 GS
The following 2 users liked this post by JoeD-C8:
Chadrad (03-16-2021),
Freerider969 (05-05-2022)
Received 2,054 Likes
St. Jude Donor '13
BigBlock-
Sorry to hear about your problem.
Our 2017 is a Z51 and they are less prone to wheel damage than the wide body cars. But by 30k miles on the bombed-out roads of Illinois, we have bent 5 of the 8 (two sets, summer & winter) factory wheels.
Only one was bad enough that I could feel it, and that was fairly minor. But I don't like driving on bent wheels.
Over a period of two years (the wheels didn't all get bent at once) I took them to a wheel repair chain and had them straightened, $125 each.
After straightening, all of them road force balanced down to 12 or less, which is very good. The car feels perfectly smooth.
I know GM says that bent wheels should be replaced instead of straightened, but there aren't enough wheels in the world to keep the C7 fleet running on virgin wheels.
So far, I haven't heard of any catastrophic wheel failures on the C7, instead they develop small cracks which cause a slow leak that gets worse.
Since I switch between the summer & winter tires/wheels each spring and fall, 5k-10k miles each time, I clean the removed wheels carefully and inspect them for cracks, especially on the inboard rim that's hard to inspect when on the car.
If I get a slow leak, I'll have it inspected for cracks immediately. You might consider doing the same, carefully.
I read a story about a base C7 with a huge number of miles (500k?) and he too has gone through several sets of wheels. On the C7, they are a consumable item like brake pads.
Received 5,238 Likes
As is said..."Pick any two of those three options"
Same problem as what?
I bought my 2014 Z51 C7 w/run flats on it that needed to be replaced. When the old tires were removed, it was discovered that the right rear wheel was bent but it still held air so I did not replace it; it balanced fine.
Now running non-runflat Michelin PPS tires at 32 PSI all around on the 19/20" rims. No additional problems noted since they were installed.
The 2PSI extra does not affect handling/road feel and I hoped that it would help reduce the possibility of additional bends or, even worse, cracks associated w/the extremely low profile tires. Haven't tried 34 PSI yet but, if I do, I probably will only do it in the rear.
For purposes of comparison, I have 18 inch rims all around on my 911 which calls for 36/44 PSI (front/back) and also have 18 inch rims all around on my BMW which calls for 32/38 PSI (front/back) and they both run fine at those tire pressures.
My left rear wheel recently cracked (and found out the other three were bent) so I purchased a set of fully forged monoblock wheels from Tire rack made by forged one for my 2019 GS A8. The ride improved immensely. I will post a pic of them on my baby soon.
The bottom line is that My GS is my daily driver tooling the streets of Brooklyn and the only real road trip was down to see my daughter in VA (400 miles each way) so I wasn't hard on my tires but those substandard (EM molded wheels were true to their history and gave out after only 2ooo miles. After installation and balancing the final cost was $3400. The only down side was that my C7 cross wing center caps didn't fit and had to use the supplied Forged One center caps. Now I have 4 beautiful paper weights
My Vette is a daily drive also.
I ran some non run-flats on my '14 with Z51 and never had a problem. I know those were not the wide wheels though.
BigBlock-
I remove and inspect mine also. But I have not noticed where the wheels are bent. I did notice the crack that developed in inner edge of my OEM wheels.
There are a couple of wheel repair companies by me. I plan on looking into that option also.
How true.
I don't have a GS, but I still have a question. When purchasing after market wheels, does any kind of warranty come with them? If so, what do they warranty?
You guys need to check where all these cheap rims are made. Some of the Forgeline flow form wheels are made in Japan which would be perfectly fine but most are made in China and whatnot.
my vote is call Forgeline and talk with them about their flowform but if you don't think what you're hearing is sufficient, then drop the cash on a set of used monoblocks. This problem will likely happen again. You could also drop down to a 19/19 set so that you've got more sidewall in the rear.
Plenty of options under 4k. LA Motorsports and BC Forged come to mind. Check out the C7Z06 forum for more options. I am running BC Forged rims.
The stock rims are rotary forged as well, you did not get an upgrade in strength over stock.
True monoblock forged rims are the way to go if you want stock sizes/width.
#33
Aren't the stock rims cast? Except for the zr1
#34
I wonder if the offsets have something to do with it as well. Are the spokes (where the wheel is the strongest) located too far from the center line? That inside edge is far away.
#35
All c7 wide body cars have what is called cast/rotary forged rims. They start off as cast rims and are then stretched/rotary forged/spun etc to make a rotary forged rim. They are also too wide of a barrel for that process.
Only z51 cars came with a forged rim, the base got cast rims.
The combination of a wide wheel, some negative factory camber, some bad roads and run flats pretty much will wreck any stock sized rotary forged rim given just time and mileage.
A monoblock forged rim is the only real solution.
#36
St. Jude Donor '18-‘19-'20-'21-'22-'23-'24
#37
Was going to post the anatomy of a run flat but don't want to insult anyone. Low profile=transferring more of the energy to the rim, more rigid sidewalls also equals the same.. My BMW had the same issues. Switched to non run flats and no problem. I wouldn't switch to non runs on my corvette but not sure of any fix unless you were switch to forged rims. Pay me now or pay me later.
#38
There’s a corvette forum vendor that’s makes a replica gs wheels.
very nice wheels...and many colors.
#40
Didn't see this mentioned, did you try to have the rim straightened / repaired by a wheel shop.
I just had 2 rims repaired, they look new.
My friends 2020 SS Camaro had 2 repaired also. Cost was $150 and they look new. One of his was cracked, that was $175.
Due to the crappy roads here, pot hole city - the shop is running 7 day a week.
