Anyone use weighted knob on MGW shifter?
Sorry, just got my second covid shot and been I bit under the weather. I haven't ordered the new adaptor yet. Will contact MGW for shaft diameter and then select an appropriate adaptor based on that dimension.
Shift Boot Retainer (TA) - was that required.
What's' that ring at the bottom of the shift ****, between the shift **** and the leather boot?
You have selected exactly what I did. The ring you mention is the shift boot collar (in the components section). It cleans up the interface between the **** and boot. I highly recommend it.
(EDIT - got it installed)
I could not get the NTA on the MGW shaft for the C7 ... so what I did was order a 9/16-18 threaded shaft from MGW, and the threaded adapter from Raceseng. I installed the raceseng threaded adapter onto the shaft, but I can't get the shift boot collar/retainer low enough for the **** to screw on all the way. Its bottoming out on the MGW shaft bolt where it screws into the shifter. Did you just not screw the MGW shaft all the way down?
So, I got it installed. I just had to back the MGW shaft out a 1/4” or so and there was just enough room to get the **** screwed in. Looks/feels great!!
For those of you with the MGW, buy the threaded shaft from MGW, and the threaded adapter from Raceseng. The raceseng non threaded adapter for the C7 will NOT fit over the MGW. ( It’s like $15 for a new threaded shaft from MGW )
I did consider doing what you did, but I was able to get this done without re-ordering parts. But if I were doing it again from new I would do exactly what you did!
How do you like it?
I got some goodness in the mail.
Here's some before pictures - new shiftboot from Redline Goods, RACENG, and a replacement boot for the bracket at the bottom to snap into place.
Replacement supply leather with Orange stitching
RACENG parts
Opened RACENG products
All the goodies
RACENG parts
All the goodies
That looks great! I removed my **** and filed the non threaded MGW shaft down so that the non threaded adaptor went all the way down, which worked great.
How do you like it?
How do you like it?
#33
This guy won’t slide down
Stuck on this lip. I expect it to slide over this shaft
Another angle
So I’m getting ready for the final install and the adapter doesn’t slide over the shift lever like one would expect. What key step am I missing?
#34
it won’t fit. I ended up ordering the threaded shaft from MGW and threaded adapter + boot collar for TA from Raceseng
alternatively you can file it down like another member did but I opted to just buy the parts
#35
I dont have a link but you can Google raceseng shift ***** to get their website. Yes it does require an adaptor (sold on their website). Just a note - I purchased the adaptor for the standard C7 shifter, but the MGW shaft is slightly larger in diameter, preventing the adaptor from sliding completely down on the shaft. Result is the **** is currently about 1/2 inch higher than it could be. I'm in the process of ordering a new adaptor that fits all the way down the shaft. It does not affect the performance of the new ****, fit is still tight, but I think I want to get it a bit shorter.
if you have a flat stick then obviously that will require a different adaptor.
What was the new adaptor you ordered to fit down the shaft all the way. What's the model number. Also did you order anything different from MGW. Thanks for the clarification.
#36
Hey @Clareymark how did you get this installed?
i just arrived at the same path you did. Also ordered a new **** (Orange), so my brand new black leather **** will be up for sale shortly with the standard C7 adapter.
any tips or lessons learned from your install?
#37
#39
Raceseng 0811056 9/16 by 18 Threaded adapter for a C5. Ordered the 9/16-18 threaded shaft from MGW
All will arrive in the next week or so.
note this is for the standard round shaft MGW. Will post pictures so mine looks as good as yours.
#40
MGW C5 part 9/16-18 threaded Rod
Raceseng part on the MGW part.
Remove the old shaft part from the MGW shifter
Follow instructions for mounting it all together and install the shift **** from Raceseng.
The big reveal....
Not quite a match to the Sebring Orange Rev Match paddles, but good enough for this summer
Comparison of C7 shift **** shaft on right and the Raceseng shift **** 9/16-18 threaded shaft which is a MGW C5 shaft mated to 0811056 Raceseng Threaded adapter
Parts are here, photos to follow
