Looking for some pics of 20"/21" tire wheel combo
Looking for some pics of some 20"/21" tire and wheel combo's with wheel brand and tire size's please.
Following as well. When / if my wheels crack/bend, I'm going with 20's all around, so looking for sizes upfront
Received 1,679 Likes
Before buying these HRE/Pirelli wheels/tires used, I had tried a set of slightly wider-than-Z51-width TSW's which were very nice but the offsets didn't allow me to go much wider with the tires than stock without rubbing issues - thus, the HRE's. These look very similar to the TSW Nurburgring style I had but the quality is turned up quite a bit.
HRE diameters are 20" x 9.5" front and 21" x 12" rear. The Pirelli's that came with the HRE's were 285/25/20 front and 375/20/21 rear. Note: The 375's were not a true 375 mm, but closer to 355 (13.5" tread).
. . . And they fit on my Z51 Stingray. No rubbing. Granted, I had to raise it back up a bit (had it lowered all the way on stock bolts) but the extra meat was well worth it. HRE really knows their offsets.
Unfortunately, one of the rears showed up from the seller with a small gouge in the sidewall that he was not aware of and had not made itself known until I mounted the setup so I replaced them shortly after the install with a new set of 325/25/21 Pirelli P Zeroes. Pirelli no no longer offers the 375 width and there is a very limited selection of 21" tire sizes so I was forced to settle on a 325 mm width. The 355/30's would rub so I steered clear of that size.
Rear Shot with the 375's
510C6Vette (01-05-2021)
^^^^ Great setup and wow beautiful looking Vette.
