rear differential fluid change
Going to change rear diff oil on my 2019 Zo6 have 3 questions
1- should car be cold, warm or hot
2- Have a quick jack and can use bigger blocks in front lifting car with slight angle to rear, good or bad idea
3- Do I have to drive car and recheck fluid level if I get all 3 quarts in
NortonCO (11-06-2020)
Warm or hot. the fluid will be less viscus and drain more freely.
I wouldn't use blocks. It may upset the balance of the car on the quickjack.
Loosen the fill before the drain is REALLY good advice.
If the car is level, then no, you don't have to recheck. That said, it can't hurt, but once it runs out the fill hole, it's full...
The following 3 users liked this post by rrsperry:
Keep the car level, or when you go to fill it you will not be able to get all the fluid in.
As the others said, make sure you can get the fill plug out first. That drain plug is a PITA to get to!
Received 5,245 Likes
As noted, if done on the level and filled as directed, it will be fine. Doing so, however, you may wish for a fleeting moment or two that you'd gotten the entry-level Stingray with nothing in the way of accessing the two plugs.
Just finished, not so bad with swivel head ratchet. What was bad was I only got 2 quarts out!!!!!! Thank You GM.
Replaced 2 3/4 quarts b/4 starting to weep out, will take it for a spin tomorrow and see if I can get any more in.
Think any damage was done to rear?car has 800 miles.
Ron_Attleboro_MA (03-10-2021)
Vette Jockey (03-14-2021)
The following 5 users liked this post by rrsperry:
hanks10GS (03-17-2021),
Jmhornz71 (03-12-2021),
NortonCO (11-06-2020),
Rky Mtn C6 (03-18-2021),
thompstl1 (03-20-2021)
Dennis Bernal (03-18-2021)
Don't panic. Just do a swap and you'll be OK. It is a break-in thing. It's also a problem with many Corvettes that came from the factory with under-filled differentials. Some reports of numerous differentials coming 1 quart low from the factory.
[QUOTE=slant6;160246542
“Replaced 2 3/4 quarts b/4 starting to weep out”
[/QUOTE]
I wouldn’t worry about it. Car was probably angled downhill (not level). Might try putting a long level against metal plate covering mid pipe exhaust next time. Course I’m assuming it is level to the differential/car!😜
[/QUOTE]
NortonCO (11-08-2020)
I'm somewhat old school so I, too, prefer to change-out break-in fluids. I did the engine at 500 miles, as required. I swapped the transmission and rear diff at 1500 miles because I wanted to.
Received 2,060 Likes
St. Jude Donor '13
And I think they recommend changing diff fluid every 15 hours of track time after that first change.
Don't have the Manual with me now.
St. Jude Donor '22-'23
I have an appointment to get mine done right after Thanksgiving. Question that I have is should I just have them put in the GM spec or is there another brand that is better?
St. Jude Donor '13
Most people I know just use the GM spec fluid.
That's what I did.
That's what I did.
javenius (11-20-2020)
