Battery changeq question
Have been reading here about losing settings when changing batteries. Purchased my 2019 new last summer with only single digits on the odometer and know for a fact that the car had been on the lot for some months. Since I am definitely technology challenged I hate the thought of resetting all the displays, etc. Read a post here that sounds like the right idea for me. It talked about plugging a power source into the cigarette lighter port in the trunk area. Someone mentioned a 9 volt battery for power. Have the "Corvette Battery Maintainer" which would not work. Searched a couple of auto parts websites and Amazon for such a gadget and came up empty. Can someone point me to a place to purchase this device since I know the battery store where I trade doesn't use one? Thinking that I will probably just get another year out of my battery and then replace it preemptively to avoid the hassle. Any other thoughts will be appreciated.
Another year on a 2019 battery? It should last you at least 5+ years!
I just changed the original battery on my 2014 this year and use a trickle charger when the car sits for weeks/months. When I replaced the battery I didn't lose any settings it was disconnect for about 30 mins. Only the TPMS and Window Indexing need to be reset.
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,831 Likes
2015 C7 of the Year Finalist
YOu won't lose squat with a battery swap. You will need to Re-index the windows.
Elmer
Elmer
Keep in mind that if you do connect some type of memory maintainer while swapping the battery, which as posted above isn't necessary, the battery terminal will essentially be live and you will need to take care not to ground out the positive battery cable.
The following 2 users liked this post by George_L:
Bavaria (07-13-2020),
geraldschumann (07-11-2020)
Read about the CTEK's model 7002 smart charger. It is the best trickle/full charger in the world. Read about their "Supply Mode" of this charger on page 10. The is exactly what you are asking for. This charger is supplied with many of today's super cars.
https://cdn.shopify.com/s/files/1/01...07522301633849
https://ricksfreeautorepairadvice.co...ery-sulfation/
Received 2,057 Likes
St. Jude Donor '13
I'm the Grammar Police.
A trickle charger puts a small but constant charge into the battery, whether that charge is too much, just right, or not enough. There are better ways now.
As you said, a smart charger/tender/maintainer is the way to go. Any one of those will vary the charging current according to what the battery needs.
Gearhead Jim (07-11-2020)
Received 5,239 Likes
I've a power-maintainer with a 9-volt battery sold for that very purpose. I bought it years ago at a local parts store. I've used it many times with many vehicles... no problems.
It is a "NOCO Settings Keeper BTE296" and even came with the battery.
In my opinion you are worrying unnecessarily as you should get 5 years out of your battery if taken care of even if it did sit on dealer lot for months. And when you do need to replace it should not have to do anything except re-index your windows.
The way I look at this car is to imagine you have a R/W CD in the car (you don't, but I did say imagine). When you select your settings, the information is written onto the CD. WHen you change your settings the information is rewritten on the CD to reflect your new settings. When you disconnect the battery, the information is not lost. When you hook up the new battery, the car reads the information off of the CD. Usually, the only thing you need do is re-index the windows. That takes maybe 10 seconds a window. Push the button down and lower the window to the bottom. Lift the button and when the window is back at the top, continue to hold up on the button for 3 mississippi's and then release the button. Do the same thing for the other window. Indexed. Drive and enjoy. You really don't need to try and keep a 12V on your system for a battery change but if it makes you feel better, have at it!
Elmer
Elmer
Received 19,414 Likes
'20-'21-'22-'23-'24
