2LT dash damaged!!! What could cause this?
Huh? I believe the OP is referring to the below. A Magic Eraser ain’t fixing that...
The following 2 users liked this post by sTz:
NortonCO (06-04-2020),
SingleTrackMinded (06-05-2020)
Yeah, I’ve used those vinyl repair kits, and it’s difficult to match the color and texture. It’s not impossible, but there is a learning curve. Personally, I would have someone who repairs upholstery look at it... Something caused it to melt/disintegrate in those three areas, and the area in the first pic. Unfortunately, this is not going to be an easy fix.
Clay bar is an abrasive. I have used clay bar for many years n my autos. Paper towels are abrasive. We still use mild abrasives on our automobiles to clean. Like I mentioned before, I have used Magic Erasers for many years on my autos and on my leather interior. It is effective and it is definitely not like sandpaper, if it were then people who detail automobiles for a living would be using them to wet sand paint. They don't. I have detailed autos longer than you've been alive. Magic eraser is safe to use. Scrubbing though would not be recommended for this application. Nor would I scrub anything with a paper towel. Gentle wiping would work effectively. I know from experience.
Abrasives have their place in car care. For example, we use swirl removers and other abrasives with a random orbital on paint, etc. One should however be aware you are using an abrasive and act accordingly. A Magic Eraser is an abrasive.
"Melamine foam is an effective abrasive cleaner. The open-cell foam is microporous and its polymeric substance is very hard, so that when used for cleaning it works like extremely fine sandpaper, getting into tiny grooves and pits in the object being cleaned." See, e.g., here.
What don't some of you see? His dash is missing chunks in three different places. Cleaning it, 303, magic eraser is not going to do anything as his dash is damaged! Plus magic eraser in the wrong hands can do more harm then good. You have to be extremely sure it will work in your application.
The following 3 users liked this post by Let It Ride:
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,837 Likes
2015 C7 of the Year Finalist
Looks like the dash has 3 divots in it. No fix for a divot except to replace the dash. Some chemical was applied and it ate out those 3 sections of dash. I use a damp towel for my dash. Nothing chemical ever gets on there as I only use water. I think you guys are looking at the tree reflection in the windshield.
Elmer
Elmer
Are you the original owner? It almost looks like it could have been caused from something being mounted on the Dash given how similar they are in the 3 spaces. I wouldn’t think rubbing because it’s not just the edges and wouldn’t think any sort of chemicals would cause this given how similar the 3 marks are in just those 3 places.
Elmer
Elmer
blkvet6 (06-04-2020)
It was being washed in 100 degree heat with the sun directly in the windshield at my work facility. I know he uses a product called Finish Renu Diamond Gloss on the dash which is a water based cleaner for rubbers, Vinyl's and plastics. He's used it before and no damage ever occurred. I not sue what class cleaner he uses.
Yes im the original owner and nothing has ever been stuck to the dash. I had my car washed by the same detailer 3 weeks ago and they weren't there then and now right after he got done with the inside he called me out and told me to look at my dash. He notices any imperfection on the cars and he even told me he didn't see it last time he washed it.
#33
The outside air temp may have been 100 deg F but the temperature of the dash material will be significantly higher depending on how long the vehicle has been sitting outdoors. If you now apply a protectant (regardless any brand) that was stored indoor at room temperature you can easily create a condition of thermal shock (stress) to any material making up the composition of the dash and could lead to the dash material to crack. A detailer should never wash or detail a vehicle in the hot sun. Most any automobile detailing product label will warn you to not apply, or clean, a vehicle under these circumstances.
#34
The similarity of the divots and their symmetry wouldn't likely be the result of a chemical reaction... On a 100 degree day in full sun, a black glareshield temp is gonna be pretty toasty... Perhaps there are metal brackets below the divots that got hot enough to melt the material above?? Interested to hear the outcome...
#35
Would you guys confront the auto detailer with no direct proof? I think i have to buy a suede dash cover now which i don't really want too. The dash is $900 but the install I heard is around $2000 from the dealer.
#36
Were it me, I'd buy the dash, youtube a dash replacement to death and then I'd do it myself for $2,000 less than a dealer. It might take me a week to do it but I'll be damned if I'd let a dealer charge me for labor for a dash replacement.
Elmer
The following 3 users liked this post by eboggs_jkvl:
#37
#38
I think your on to something and I it noticed also. Those divets all look the same and are evenly spaced. They are too perfect in reference to each other for a chemical reaction to have caused this. There is something else at play here and pulling the dash I guess would give you some clue, I don't see any other way.
Could the Suede Piece be rubbing on the dash and cause that? I did add coil overs to my car and the suspension is so stiff now that body panels are now rubbing together now and the paint is flaking off in some areas as well.
Also in my first pic the same is happening where the speaker is meeting the dash.
#39
There are mobile professionals that can come out to your house and fix ANY issue like that on your dash or seats. Don't fix it yourself and make it worse!
Call the service managers at some BMW or MB dealers and ask them who they use for leather repair if you do not know of a skilled one. They can repair it and you won't even know it was ever damaged. Don't just use anyone from the phone book. Find the best!
dcarr (06-04-2020)
