Dielectric grease
Dielectric grease
Ive always used Silicone Spray to treat the weatherstripping in the back hatch to keep it from sticking. Based on feedback here i tried dielectric grease. Used it in a small spot first and it leaves a terrible greasey residue collecting dust and dirt. I tried to work it in the best i could. Am i doing somthing wrong?
Popular Reply
03-21-2020, 04:47 PM
Received 1,322 Likes
I used dielectric grease until another forum member suggested this:
Much less mess. Available most auto stores / internet.
Ron
Ron
Gummi Pflege Stift
A bottle will last your for years but the dispenser will kind of denigrate after a few uses. I covered it with some thin cloth from an old t-shirt and tied it on with a tie wrap and when that wares out I replace so the original top still works. Other than that, this is the only stuff to use. No mess, no sticky residue. Once a year is all that is needed.
I tried a type of grease like you and had the same results. So 99% of the time I use silicone spray. I have also used a spray dry lube which seems to work pretty well.
Maxpowers (03-21-2020)
Why would you use dielectric grease? I agree with others, silicone if you’re old school or one of the new rubber conditioning products.
Received 2,067 Likes
St. Jude Donor '13
P. 299 in the Owner Manual for our 2017
GM also makes a special weatherstrip lube, I'm surprised they didn't recommend that. But it's hugely expensive and seems to evaporate and leave a film inside the windows, even if wiped down after application.
The dielectric silicone grease is tolerable if you apply out in the sun on a warm day, rub it in, and then wipe off as much as possible.
The following 2 users liked this post by Gearhead Jim:
Crossed Flags Fan (03-23-2020),
The following 6 users liked this post by RonC7:
donkeyhoeti (03-23-2020),
geraldschumann (03-24-2020),
joemessman (03-23-2020),
Maxpowers (03-21-2020),
NoRuls (03-22-2020),
and 1 others liked this post.
The following 3 users liked this post by RMS73:
Thanks for the feedback all.
Jim - you hit the nail on the head. I applied the grease at 45F. As the sun came out it was more plyable.
Im taking it off and exploring options others provided.
Maybe because that's what GM tells you to use?
ah, dielectric SILICONE grease. Did not know that. Thanks
I've been using dielectric grease mainly because the manual specifies it and I had a tube lying around. I've had no dust or other issues although the grease is, well, greasy if you use too much. I apply it, then wipe most of it off with a cloth leaving only a thin film. I think any preservative recommended for plastic and rubber--e.g., Armor-All, 303, Lexol Vinylex, etc.--would work fine. I used Armor-All on my C2 for 32 years on the seals, vinyl seats, dash, etc. and never had a problem. I applied, let dry for a short time, then wiped off
Received 5,277 Likes
Silicon... wipe on, wipe off.
I have used GM Super Lube® with PTFE, P/N 12371287 (in Canada, P/N 10953437) in several previous C6s and my C7 for the "snap/crackle/pop" issue. Worked for me overall quite well....always have a tube in the hatch.
St. Jude Donor '13
When the Superlube recommendation was in effect, I cleaned my C6 weatherstrip and applied Superlube. A year later, it had turned into a gummy gooey squeaking creaking mess. It took most of an afternoon to clean it off and go back to the dielectric silicone grease. Others had the same bad results, but obviously not you.
I used this on my vert top seal and has worked great... squeeze the top and it comes out on its own
https://smile.amazon.com/gp/product/B01N6B1VW9
CRC 5113 Grease
https://www.crcindustries.com/produc...-oz-05113.htmlhttps://smile.amazon.com/gp/product/B01N6B1VW9
