I need help
I need help
I have a 2016 Stingray.The right door will unlock when I approach my car.The left door will not unlock. I have to use my transmitter.I have read the owners manual and I tried every thing in it. Can anybody please give my some help? Thanks,Rod
Scientific Negotiator
Received 1,837 Likes
St. Jude Donor '07-'08-'10, '14
Hey Rod,
See if this works, on your infotainment settings select all doors for passive door unlock. Odd that it’s your left door that doesn’t unlock tho...
Select All Doors or Driver Door.
Passive Door Unlock
This allows the selection of what doors will unlock when using the door handle sensor on the driver door to unlock the vehicle.Select All Doors or Driver Door.
Received 3,447 Likes
On the Mylink infotainment screen go to Settings, Vehicle, Power Door Locks, Auto Door Unlock, and then choose All Doors.
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,830 Likes
2015 C7 of the Year Finalist
Sounds like the touch pad on the driver's side is not working properly. They aren't expensive and it takes <15 minutes to swap out the pad.
To be sure, when you pull on the driver's pad to open the door, nothing happens? Correct? When you do that to the passenger door and/or the trunk/hatch both open?
Elmer
Elmer
Elmer
Elmer
Your fob battery may be getting weak. Change it and see if it solves the problem.
I can't remember the EXACT procedure but I had a similar issue with my previous car (C6) I removed the door pad and cleaned everything I could find and that fixed the issue.
Elmer
The following 3 users liked this post by Mayor111:
Found the problem
Found the problem guys.The wire to the antenna fell off.The wire was loose and wasn't making contact.The tech. tightened the end of the wire so it won't ever fall off again.He wrapped a piece of tape over the connector and I am back in business. Thanks to all who replied to my problem. Rod
The following 2 users liked this post by ROD BROWN:
joemessman (01-22-2020),
ScottMA64 (01-21-2020)
Finally got it
[QUOTE=Silver C7;1600850488]I remember your "Victim Of The Strike" thread...Did you ever get that car back or is this a new
I finally got my car back on the 17th of this month. It was a long wait.This is a new thread. Thhe tech found the loose wire and slipped on to the connector.As soon as he installed the wire the door worked..I am happy.It was a long
wait.Sept. 17th to Jan. 17th.It was one long walk every day. Thanks to all who gave me a lift when I was in need.Rod
