Brake caliper press tool
Does anyone think this is useful or are there cheaper solutions?
https://charttricks.top/products/brake-caliper-press
Received 1,679 Likes
There are cheaper solutions but the ones I have used seem to break easily. ^ That one looks pretty good.
Mayor111 (11-29-2019)
You can almost always improvise. Wheather it be using a c-clamp or a giant pair of channel locks or whatever, there isnt really a need for special tools just to push caliper pistons back into their bores.
There's many different types as I probably carried a 1/2 dozen or more versions when I owned my auto parts stores. As stated above, a "C" clamp works as good as anything.
Fingers / hand / old brake pad...
Received 19,391 Likes
'20-'21-'22-'23-'24
C clamps have always worked for me.
Received 5,238 Likes
Looks like one of those instances where one might get what one pays for. However, they seem to show two different versions at the link above.
I use this https://www.girodisc.com/Caliper-pis...er_p_5970.html but I change pads several times a month. For me it's worth it but if I only changed them once every year or so I'd use a c clamp.
Scientific Negotiator
Received 1,837 Likes
St. Jude Donor '07-'08-'10, '14
Mayor111 (12-02-2019)
I went to the same school of old pads and fingers. Always worked for me.
I didn't need an special tools for mine. Just a little prying pressure did the trick. Replacing the pads was a very simple job without the need to remove the calipers.
I track my C7 and thus change pads often. So I tried various products and this tool is the best. They are hard to locate, I ordered my off some specialty site that I can't find right now. They sell a narrower version on Amazon but this wider one handles the 4 piston Brembos. No need to remove the calipers either. The tool is super heavy duty with a hex nut on the end so you can turn it with a socket or wrench.
[QUOTE=JMII;1600584499]
I have this tool as well. I got it from Amazon and it works very well.
