Installing ACS side skirts - alternatives to rivets?
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03,'04,'05,'07,08,'09,'10,’17
Love how the ACS Zero rockers come pre-drilled, therefore, they are their own template.
I've used rivets before, and have a small cheapie rivet gun, but I would rather uses something else. I don;t think I want to use double sided tape.
What about self tapping screws, or these push pins?
This is just my opinion, but I'd recommend investing in a good quality rivet gun. Then, go to a Napa or similar store, and they should have bags of automotive rivets that match exactly with what ACS provided. Then, practice riveting various **** to make sure you've got it down. Allow yourself plenty of time and use what the instructions state. Measure twice, cut once.
Again, just my $.02.
need-for-speed (08-10-2019)
Received 1,762 Likes
ttt
Man use the D/sided type I have had mine on the car over 3 yrs now with no signs of come off r anything... I used the 3m. Robert
Just take it to a shop and pay. I use a pneumatic rivet gun. Takes 5 minutes. If you dont have that kind of access to equipment bring it to someone who does a friend a ppf shop will often do them as well as probably any decent detail shop. It's considered less than C tech work. Like apprentice level skill.
That is what I used, along with oversized washers AND double sided tape. I track my car so I needed to be really sure they stayed put at high speeds. I'm sure its overkill but the effort was no different then rivets or push pins. Just make sure you don't drill too deep or you'll go thru the floor of the car and into something important. I believe the automatic transmission cars have cooling lines running behind the rockers so watch out!
CI 1-4-5-8-9-10 Vet
Thanks but I am going to do it myself. My mechanical skills are just fine. I’ve completely rebuilt my 79 Camaro including the suspension, interior, engine and 700R4 retrofit. I did everything but the paint. I just like to learn and ask questions before I drill the first hole or make the first cut. That should not be mistaken for a lack of ability.
kyle tegtmeyer (08-09-2019)
CI 1-4-5-8-9-10 Vet
Thanks. I plan to mark the bit, or put washers on it to prevent from going too deep.
do you recall what size screws you used?
CI 1-4-5-8-9-10 Vet
Have they been “wind tunnel tested”
CI 1-4-5-8-9-10 Vet
CI 1-4-5-8-9-10 Vet
Great idea with the washers to spread the load. I will do that as well.
Rivet nuts, makes for easy removals .
The following 2 users liked this post by AmmoVet:
Avanti (08-09-2019),
joemessman (08-10-2019)
Received 19,379 Likes
'20-'21-'22-'23-'24
I used a combo of a couple of screws and some plastic rivets that I got from a local body shop. Been on the car for about 4-5 months and they are rock solid.
Received 5,236 Likes
Riv-nuts would be a no-brainer for me, IF you have an appropriate material to "set" them in. I've used them with great results on many race cars.
(btw, you may wish to do a search here; as I recall, depending on your model C7, there may be some lines that run through the driver's side near where you will be drilling, etc.)
I've never seen a group fret so much over rivets. I can count on one hand the number of people that have managed to destroy a side skirt and it's not like rivets are a big deal to drill out. At any rate...
GM uses large head exploding rivets. You can buy 50 of them for ~$15. Good enough for 200+ in the ZR-1, good enough for me.
They work just fine from first hand experience as well...
with that same "ability" here's a thought... use your rivet gun and install them the way the factory does instead of dicking around with these half assed install "tips" there's a reason they use the exploding type rivets.. we've had members cars rest on the rockers installed with rivets and the rocker extensions stay on saving the car.. doing it a half assed way? have an incident and it'll be a trip to the body shop instead of "just a new rocker extension" you need the size and type? i buy them on amazon 48qty for like $14 to my door. just ask. good luck.
CI 1-4-5-8-9-10 Vet
GM uses large head exploding rivets. You can buy 50 of them here for ~$15. Good enough for 200+ in the ZR-1, good enough for me.
Please educate us.
PS that is the same combo i ordered for my new Z06 being built at the end of the month too lol... beautiful car.
