2015 splash guard question
Looking for the GM OEM splash guards for my 2015 stingray convertible. I found part numbers 22935635 and 22935639 but GM Parts Direct says they don't fit the 2015. There's a chart I found on eBay that says they fit 2014, 2016, 2017 and 2018. Whats up with that?
I have these exact splash guards installed on my 2015 Stingray coupe as ordered from dealer.
chuck754 (06-07-2019)
Received 2,639 Likes
That's odd. The ones on my previous '16 base Stingray fit perfectly on my now '19 GS. Not to cast dispersion's on GM Parts Direct, but I think you talked with someone that has no idea what they are talking about. Call CULTRAG, they'll help you for sure.
Plus, I never depend on Ebay's fitment chart. It's wrong more than it's right. And it's wrong again in this case. If they fit the '14's and '16's, they'll fit a '15.
I have an old set (front and back, no bottom clip; used it on the replacement part) from my 2016 when I replaced with extended version.
I can dig it out from the garage if you want and send it to you. Just pay shipping
Let me know
i can take a pic if you want.
Let me know
Thank you...very thoughtful. I think I want a new set though.
No worries.
In my opinion, since your getting new ones, I would get the GM extended. Helps protect a little more, and doesn’t extend out too far. I added the extended on the new Z06 but not painted
Good luck 😎
Painted carbon flash
Rear
Front
Good luck 😎
Rear
Front
They look great!
Thanks again!
Thanks again!
Received 5,238 Likes
I, too, vote for GM extended. They add a little protection and are nothing to install. No reason they shouldn't have been on all from Bowling Green. And, they are made in China!
The pieces are so small, that I just wiped them down and sprayed it with carbon flash paint and clear coat.
it was much cheaper than buying the painted ones.
The paint that matches the carbon flash can be ordered online.
If you need info, I’ll dig it up from home, but there’s a guy in here that used it to paint the poverty splitter 😎
Received 19,394 Likes
'20-'21-'22-'23-'24
I would bet they will fit just fine.
They fit the 2015. I put these on my 2015 Stingray, then two years later my 2017 GS. No fitment issues for either.
Glad you are happy with them. A quick addition that will help prevent some rock chips down the side of your car. That was the first add on for my 19 GS when it had 100 miles on it.
