Tire storage solutions
Hey everyone
Just wondering how people are storing extra tires in their garage. I saw Amazon had some wall mountable tire storage racks but they look suspect. Wondering if anyone came up with something on their own or bought something. Damn GS tires are so big it's taking up a lot of garage floor space so would definitely like to get them up and out of the way.
Pictures are much appreciated. Thanks!
Popular Reply
05-14-2019, 07:35 AM
I stacked my original wheels and tires off my '99 and made a bar height table. I mounted some low profile casters to a piece of plywood so it can be moved. I also bought and finished a round table top for the top. It solved my problem hope it helps with yours.
Hey everyone
Received 19,451 Likes
'20-'21-'22-'23-'24
When I had extra wheels/tires for my C5, I put down a thick piece of old carpet on the garage floor then stacked the wheels/tires on top of each other with a piece of cardboard in between each one. Worked well for me.
The rack you can mount to wall studs seems like it would work well too.
I stack mine on a covered pallet. Works fine.
The following 13 users liked this post by JohnnyDee:
Apocolips (05-14-2019),
Co-Vette (05-17-2019),
cor66vette (05-14-2019),
donkeyhoeti (05-20-2019),
dsword (05-18-2019),
and 8 others liked this post.
I gave up and bought another rental property. This one is two minutes from my home, and has a detached 2 1/2 car garage behind it (and seven acres). I rent the house out and keep the garage for my personal use. It's not a big money maker, but how many tire storage solutions pay you $3,500/year?
Received 2,688 Likes
2018 C5 of Year Finalist
I placed my OEM wheels and Cup Tires in the Forgeline shipping boxes and stacked them in the corner of the garage.
Because of a lack of space in my garage, I needed to hang my tires flat against the wall. I used a some heavy duty shelf brackets that I purchased from my local big box building supply store. I flipped the bracket so that the long side is mounted on the wall. When used for shelving, I believe that the long side is usually used to support the shelf and the short side is bolted to the wall. I mounted the bracket with lag screws directly into the studs. Then, I split some heater hose and put it on the top of the bracket to prevent scratching my wheels. I think there was a sticker on the bracket indicating that they were good for 600 pounds. For the 4 brackets, lag screws, washers and heater hose, I think I spent about $35.
The following 4 users liked this post by ddrag1:
This is what I do:
ddrag1 (05-19-2019)
Hey everyone
Received 2,061 Likes
St. Jude Donor '13
Thinking a bit outside the box (garage)...
We have a hillside ranch house with a walkout basement and sliding glass doors, plus an unfinished area that we use for junk storage.
Being lazy and not having a lift, I let the dealer swap between our summer PSS and winter AS. Since they flush the brake fluid once a year, that swap costs me nothing extra. The other time, about $25.
After they do the swap, they load the removed wheels/tires into our beater. I drive 15 minutes home and around the back of the house. Roll the tires out of the car, across a throw rug that's flipped upside down to protect the good carpet, and into the storage area. There's a big trash bag & piece of cardboard on the concrete floor, stack the tires with cardboard in between.
The storage area is cool/dry/dark. Temperature never gets above 75' or below 55'. No worry about the 20' limit on the PSS.
This won't work for everyone, but works for me. Life is good.
V Vette (05-19-2019)
St. Jude Donor '17, '19
I think I would use some left over lumber and build a rack before spending 140 plus shipping on a rack.
But mine are stacked on the garage floor, wrapped in garbage bags (to keep me from getting things dirty with them, not really for protection) and pieces of cardboard between them. The large 20" rims stick out a bit and will touch the floor, so make sure they are not the bottom.
