Infotainment Hack
Infotainment Hack
Has anyone heard about a hack pf the Infotainment system to change the map colors? I have a 2014 convertible and the gray/green display is unusable on a bright day or with the top down. I'd like it to be bright white like the Japanese cars.GM Infotainment is a drag on sales for GM. We are looking for a new car of a different type and we won't even consider GM because of how bad that system is. So many parts of the interface, like entering a new preset station, are so counterintuitive that people go to the dealers to get help programming. I guess the only way to try to influence behavior is to advise people to avoid GM because the technology sucks.
Was this a question or a statement ???
how hard is entering a preset station, all you do is hold the button and it will set as a preset ....I dont think GM is losing any sales over it lol
Now you want a system that is not user friendly, you should try to use the infotainment center in my AMG ......not initiative at all .....
Dave
Dave
Dave,So how does the display look when you have the roof off?We also own a two different makes of Japanese cars. With the sunroofs open the map displays are very readable.It looks like we don't agree. I'll do what small things I can to highlight the limitations of the system in a way that matters to GM.Perry
I cant say I‘ve noticed that particular problem in my coupe w/ the top off.
You can always set the dash display to NAV, which shows upcoming turns, and it also appears in the HUD,
Now if for some reason (like the light sensor on the dash is covered or not working correctly) and the system goes to night mode, ya, I can see where the entire screen would be tough to see. Both my driveway and parking space at work are heavily shaded, so at power on, all systems switch to night mode until I get out in the sun.
It’ll sometimes switch when driving down a narrow tree lined road.
Perry , as AJ states above , I also dont have a problem with seeing the screen with the roof off and I dont have a problem programming the radio . Maybe is it possible that you dont have the brightness turned up?
Now I can see someone with a convertable maybe having an issue where the sun might wash out the screen but not in my coupe
Dave
Dave
II haven't had any problems with viewing the screen in my 2015 top on or off or in my 2013 Buick Enclave with the sunroof closed or open
Can't comment on the map colors because I have a coupe with tinted windows and use my phone for nav 90% of the time.
Moderator
How are you guys making it so difficult to add a station preset? All you have to do is tune to the station and then press and hold the button you want to set. How can it be any easier?
By default the preset list isn't shown. You have to tap that little arrow to display it. Even then I couldn't get it work I had to use the Browse list, then click on a station and select add as favorite or something like that. Everyone just says "hold the button" (same thing in manual) but if preset list isn't up then there are no buttons. All the screenshots in the manual show a simplified version of the interface instead of a real picture which made things confusing. Also the touchscreen isn't responsive like an iPhone, dragging or sliding in particular only works about 50% of the time for me.
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,402 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
Me thinks the OP suffers from confirmation bias
JMII (10-01-2018)
I've installed car stereos as a hobby for years and was dumbfounded by GM approach to presets.
Complete joke that having two rows blocks the information above it, really sloppy programming.
Just about every audio system I've used in other vehicles is better then Chevy's MyLink, but I doubt its costing them much sales or service wise or it would have been fixed by now.
Yes I appreciate stuff that works. Due to my job I have to rent vehicles often and I stand my statement that Chevy's MyLink is subpar compared to other systems I have encountered.
What do I win?
P.S. Don't tell your family as I have left the "family tech support" arena years ago when I installed Linux at home. Now I just say "Not sure sis but it works on my Linux box...".
Oh I grant you 100% that the MyLink system sucks *****. See any of my posts. It's really a PITA to use. AA and GM however is far superior to any system I've seen so far. Quite frankly the only time I use MyLink and the factory nav is when my phone's battery is completely dead.
Dave,
Thanks!
It's a convertible. We have two other cars with nav systems, a Nissan and Toyota, and the background on both is white. Both are SUV's with sunroofs so it isn't precisely an apples to apples comparison - but they are readable regardless of the outside lighting. Ditto a Garman I sometimes use in the C7 and my C3.
If Chevy had counter sunk the display in a recessed "tunnel", like Lexus does, instead of putting that little compartment behind the display that would fix it. Also, display color would seem to be something they could have made a software option. GM seems to have a case of the Microsoft Disease which is they think they know what the customer wants and needs better than the customer.
Besides using the Garmin when I need a top down nav system the only impact for me is to avoid GM products when we buy our next SUV.
The C7 is also an early production 2014 and they have probably fixed a number of annoyances.
Break Break
I figured out the radio but it took a while. Getting the push buttons off the map was simple matter of using a fixed number of tiles. I finally stumbled on saving the stations to the correct tile. I seldom change those presets so it requires a learning curve every time. The process is different than the other onboard nav systems I've encountered.
Perry
Thanks!
Break Break
Perry
