Surging with Range device?
So, I tried my Range device for the first time last night. I don't have any TC issues yet, but I wanted to be proactive.
I definitely did notice a difference, but I'm not sure I liked it. I drove both in town and highway, using cruise. It seems like the car wants to surge just slightly and only for a split instant. I don't know if this is the car wanting to go into V4 mode and the range catches it and prevents it or??? That's almost what it feels like. Has anyone else noticed this?
Shifts also seemed more pronounced in every gear, especially the higher ones like 7th and 8th. It was the slight surges that annoyed me most though.
I searched this and found nothing. Thoughts?
OK, I'm glad it's not just me. It's like a pulse surge. Didn't really even notice anything on the tach associated with it either, but it was there. Both my husband and I could feel it.
When does the surge occur, when tranny changes gears or after you are in whatever gear and cruising or when you first put in gear? I haven't experienced this and I bought mine from a forum member and sent it back to have it upgraded to latest version free of charge. Very happy with range and service.
Ok, got a chance to drive it again. Definitely a bit of a surge and even the exhaust note changes. This is with cruise on the highway.
However! I changed the display so I could watch what mode it stayed in... 3 times I caught it go into V4 mode. Once coming off the highway, once coming to a stoplight and another after a turn from a stoplight. So, me thinks I need to talk to Range about this.
Received 2,639 Likes
If that doesn't work givee em a call, they're good folks.
Yup... Already did. They gave me reset instructions to try. I'll see if that does the trick. It's definitely not normal. I ended up pulling it today because the hesitation was getting really annoying.
I hope the reset works for you. Keep us updated.
Rebel Yell (09-25-2018)
I've put a few more miles on mine and today almost 200 miles in Tour mode and mostly 7th and 8th gear and they were consistently smooth shifts. I had one slightly rough downshift when coming to a stop but I had those before too. I'm very happy with my Range. No problems whatsoever.
Received 1,738 Likes
St. Jude Donor '15-'16,'18
It should never go into V4 mode with the Range plugged in. Are you using a switch or directly into the OBD port?
Received 1,029 Likes
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Definitely a malfunction if you’re seeing it go into V4 mode with the device properly plugged into the OBD port. Regardless of which mode...Weather/Tour/Eco/Sport/Track ....you’re driving in, it should always be using all 8 cylinders.
I’ve had a great experience with my Ranger device....smooth shifts in all gears and no worries about TC problems.
Just let them know what’s going on and they’ll send you a new one. Keep us posted.
Well, I tried Range's reset instructions and it was still popping in and out of V8 mode. In one mile it did it 3 times all at under 40 mph.
It is plugged directly into the port. That's hard to screw up. The connection is tight. I'll have to call them again tomorrow and see where to go from here.
