My remote button to activate the convertible
08-31-2018, 08:12 AM
1st Gear
2016 C7 convertible remote for convertible will not work/
08-31-2018, 08:23 AM
I assume it works using dash button? First, check the battery. I believe it takes a CR2015.
08-31-2018, 08:28 AM
Have you used it before?
Just an FYI, you need to hit the door lock button first then hit the button to lower the top.
08-31-2018, 09:22 AM
Mine worked, but very often either my finger would slip while holding--you do have to hold it for the full cycle-- (or there was some break in the signal) and the top would stop part way. Fixed all the problems with Smarttop add-on--plus several other benefits.
08-31-2018, 09:25 AM
Another FYI, When I first got mine I was hitting the trunk release and not the convertible top button. Make sure you hit the door lock button first as mentioned above.
08-31-2018, 09:27 AM
Quote:
Originally Posted by
Kevin Parent
Hit the unlock button on the fob then the button the lower the top.
08-31-2018, 10:31 AM
Using FOB to put top down
javenius
What he said, mine works every time, I never drive with the top up.....
05-20-2021, 10:20 AM
Any error message in the DIC?A bad partition switch would give a message
01-30-2023, 11:48 AM
3rd Gear
Convertible Button Only works for the Up. Not Down
My top will go down with the Fob, but will not go down with the button. I can then get in car and put top up with button. Is this a sensor issue?
02-21-2024, 07:34 AM
Cruising
TW Jolly, Your issue is most likely the interior switch, it can be tested w/ a scan tool to be sure.
02-21-2024, 09:38 AM
Deal Maker
Manual says to lock/unlock then push top down button.
