Intermittent Vibration on smooth road
My 2015 Corvette with automatic transmission tends to cause vibrations on and off even on a smooth road. Does anyone have any idea of what might cause this? Sometimes I can drive for over 10 miles with all smooth but then it vibrates for just a few seconds. Speed does not seen to make any difference neither when accelerating.
Ted
tls1@att.net
Ted
tls1@att.net
Sounds like it could be a bad Torque Converter. Can read more here.
https://www.corvetteforum.com/forums...-tracking.html
C5A (08-19-2018)
Received 1,029 Likes
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Most likely it’s the engine going into and out of V4 mode. Mine did the same; I kept thinking it was the road surface with some slight irregularities but after reading about this on this forum, I found out that it was the AFM system kicking in and out. Luckily, there’s a very easy solution. Go to Amazon,com and order a Range device to plug into your OBD port. It will keep the engine in V8 mode at all times.
Problem solved. You’re welcome!
C5A (08-19-2018)
I took my 2015 Corvette to the local Chevy dealer and they said they contacted the experts and were told to replace the fluid in the transmission to prevent the vibrations I was getting. I can not understand how replacing the oil in the transmission would stop the vibrations but will drive it and see when I pick it up.
When the engine is in V4 mode, the Clutch Packs in the TC are constantly engaging and disengaging.
And with the Original oil, they are not operating smoothly which is causing the vibrations.
With the Original oil, sometimes it does work smoothly and other times not, or not at all.
The new oil will make/help the Clutch Packs engage and disengage smoother, and in most cases, eliminate the vibration.
Slynky (09-07-2018)
Trans fluid change
I was told busy the dealer that the new transmission fluid is designed to create more pressure and thereby reducing friction and slipping of the torque converter. Result is suppose to be smoother operation.
C5A (09-10-2018)
I have now driven over 100 miles and have felt no vibrations. I forgot to ask the dealer how long the factory power train warranty is since i am at 19k miles and over 3 years with my 2015 Vette. Can anyone tell me?
