Recommend Four Post Car Lift For Grand Sport Please
I need to locate a four post stacking car lift for a Grand Sport. I want to be sure that the extra width of the GS is not going to be a problem. My garage ceiling height is ten ft.
Would greatly appreciate any lift ideas or recommendations by company name and model number.
Hope that helps,
Greg
Both garages I have installed my BendPak HD-9 (120" wide) in have had 10-ft. ceilings. In my current grarage, I had the door raised using track extensions to have the door hug the ceiling. I also used a Lift Master side-mount opener with battery backup to eliminate the interference.
Previous setup
Current setup
Previous setup
Current setup
I second the bendpak HD9. The ramps should be set up on the wide setting as they can also be set up for narrow cars. The easy way to make it happen is to buy direct from Bendpak. They can also recommend a local delivery and install company. You may or may not need the longer aluminum ramps, depending on how low your car is in front.
