My 2014 stringray is having issues going to sleep and not being able to start
My Stingray locks the doors and sometimes when you try to enter or start it wether you remotely start, acts like you have a dead battery. The alarm light is working and the battery is charged. You can use either remote And it does the same thing, nothing but in the next 5 to 10 minutes it will wake up and everything is fine. I brought it to the dealership and they keep it for two weeks and said they couldn't find anything wrong but tried to sell me a new remote. I thanked them but tried to explain to them that both remotes can't be bad. They don't have an answer. Any help is appreciated.
Bobby
Bobby
Is the car battery original? If so, first thing I would do is replace the battery.
Our C7s are just now starting to show what wonkiness might crop up when the battery is dying (never mind the supposedly good reading on it, IMO), so not much data or stories to relate, yet, but I'm sure some odd behaviors will become commonplace as our cars' batteries age.
If you do replace it, tell us if it cures it.
Rebel Yell (09-11-2017)
The following 2 users liked this post by TNSQUIRE:
JerryU (09-11-2017),
JimNeedsC7 (09-10-2017)
Received 2,639 Likes
Replace all the batteries, FOB's & car. The car battery could show charged, but still have a weak or bad cell. As Lisa said, these cars go nuts with a weak battery. Good luck.
Wife's 2014 Convertible was doing the same thing. Turned out to be the fob batteries, $7 @ Walgreens. The battery for the car is at the end of warranty anyhow so we're having it checked as well. I do hate folks touching my cars though...
E-Ray, 3LZ, ZER, LIFT
Received 9,655 Likes
Changing the battery is not easy either or getting access when jumping! The AAA guy will surly rip the carpet!
My suggestion is to pop off the lower rear clip on the plastic wheel well cover before pulling the carpet out. no need to remove the top fasteners just that rear clip. Pops right back in with the side of your hand. (Note wood in pic was only to take the picture. Just pull the carpet out with one hand while holding the plastic cover with the other.)
Also chaged the battery in my 2014 and this is a PDF with some tricks: http://netwelding.com/Battery_Issues.pdf
If you're going to a dealer or auto supply, you could pop the lower clips first! Could even pull the carpet out!
Clip is about 3 inches up from carpet. Can pull off with your fingers or use a screwdriver (or plastic trim tool if you have them) but a screwdriver tip would only be sliding on the carpet. Note the untrimmed carpet edge.
Lonegun (09-11-2017)
