Tire dolly
#41
Sorry for the delay in responding. I just saw your question.
I believe I got the rollers from MSC Direct. I just checked their web site and saw their part #36088144 which is 13 inches in width and 1&3/8 diameter which is what I used. They carry quite a few sizes in various widths and diameters. Mine came with a bracket which made mounting them to the aluminum plate I made very easy.
Hope this helps.
Rich
Hope this helps.
Rich
However, I did find another one available from Amazon by searching for "roller and bracket" and found this one which also includes the bracket:
It's 13 3/4" wide but not sure of the diameter as that's not mentioned. The part number is TAS3500B.
Hope that helps.
Rich
AlaskaPaul (08-30-2017)
#42
How wide is the frame you built?
You can find rollers by doing search for "conveyor rollers"
Here is one example.
http://www.globalindustrial.com/p/ma...iABEgIvuvD_BwE
https://www.grainger.com/category/ro...In+Dia%2C+10BF
And to answer your question TEXHAWK0, the rack I made inside dimensions are 14" wide and 13.25" deep to the open end. I'm sorta embarrassed to post a photo of mine after seeing the others on this post, but it serves its purpose.
Now I want to make a better one with rollers and which works with my jack.
I like to tinker, and one can always learn a better way from others. That's why I love this forum so much......it's like life.......you can learn something new every day.
Thank you all for your input on this and all the other items you have contributed to............this is a great place to hang out.
Alaskapaul
#43
Thanks for your reply on the rollers. After surfing again last night I have also found many rollers in all sizes on Graingers now that I have figured out how to use their site. Here's just an example location web address for 10 inch rollers. For other sizes, just substitute another size in front of the 10BF on the search box which will come up and search again. The XXBF means between frames in inches.........I didn't know that at first, but it makes sense!
Alaskapaul
Alaskapaul
#44
#45
Tried out my new tire dollies today to swap sides and inspect my front tires.
After I lubricated the plastic side rollers, they worked better than I expected.. The hydraulic version makes it very easy to lift the tire and wheel exactly enough to line up the lugs... Removing the wheel is just positioning the dolly, removing the last lug, and rolling the whole thing straight out... Also works well to let me roll the tire once it is off to closely inspect the tread and remove anything stuck in the tire that might cause a problem later... I had what I thought was a crack on each tire, but when able to look at it closely, I can see the bottom is smooth, almost like it was cast by a defect in the tire mold... (in the same location on both front tires??)
I tried to post photos, but for some reason Corvette Forum is saying my files are corrupted...Strange they open everywhere else??
Tire dolly in action
Tire defect
Tire defect
#46
I found some inexpensive wheels that give you the added height per your measurements. I added 3 washers underneath to get it a little higher.
The wheels are plastic, but go to 300 pounds, so that 1200 so I think they will hold up for just one tire.
http://www.surpluscenter.com/Wheels/...TER-1-4300.axd
Just my solution FWIW for something to help removing the wheels with a Quick Jack at normal full height.
#47
Looks like a good and cheap solution to get some added height.
#48
Thanks for the measurements and pointer to the less expensive GoJack!
What kind of lift do you have that this small amount of extra lift really helps? For those using floor hacks, only need to lift enough to get tire off the ground.
#49
QuickJack. The QuickJack at it's lower lift height is still too tall for the GoJak.
08G8V8 (11-12-2017)
#51
Someone pointed out that even the 12" wide model will not work on Z06 tires since 335's are over 13 inches.
There are other brands that make a wider model. Look up GoJak. They make one for 20 inch wide tires.
They start to get expensive when you go up in width and weight capacity.
