Are bent Z51 wheels worth repairing?
I replaced my 2014 Z51 Chrome wheels with black Z06 reproductions a few months ago. I knew that a couple of them were bent. Probably from too many rumble strips on track days before I bought track only wheels/tires. Turns out 3 of 4 have a wobble when spun on the balancer.
So my question is are they worth trying to get repaired? And would anyone on this forum truly want a set of wheels that came with a disclosure that they had been repaired.
They're taking up space in the garage so trying to figure out the best path forward.
Here's an opinion....
If it is the rim barrels that are bent...then yes repair possible.
If it is the rim run out that is bent/ wobble...I'd say junk, this is a bad rim.
Would I personally buy a used aftermarket rim with a disclosure? No.
Good luck in your decisions.
To have a wheel trued, I believe it costs a couple hundred.
I've heard conflicts too
Getting them repaired should be no problem finding a buyer with that disclosure will be a problem.
Rim Fix
I had vibration on my c6 and had a rim guy reshape them round and got a great ride and great tire ware. The cost was about $175 per tire. I would do it again.
I have two full sets of wheels - tires for my Z51... both sets are OEM Wheels, one with original tires, the other set has cold weather Michelin AS3 rubber. Occasionally I have bent a wheel from pot hole damage (roads in the North East are horrible!) I use Wheel Colission Center in Bath PA. They are excellent both in wheel repair and in cosmetic reconditioning. I have had good experience with them with my Vettes and BMWs. They also offer a wide selection of OEM 'take off' wheels. Nice people to deal with.... If you need them to mount and or balance, they also have the latest Hunter mounting equipment and Road Force balancing machines. They now also do motorcycle wheels. Check them out....
Al Engel "Save the Wave"
No other posts in the last 2 years? Can it be safely said that bent Z51 rims aren't as prevalent as some of our friends and owners here with Grand Sports and Z06's?
I've seen very few posts regarding the Z51 rims bending. They are rotary forged which helps to some extent.
