Android Auto - What all can Android do? Tips and Tricks
#61
But I need a Navi, preferably on the center screen (not from a small phone screen).
So, my 1st question is....can Android Auto simply be used as a navigation system, without having to tie it to "to-and-from" directions? Like, just a GPS locational map, like you'd have in a car? I assume this is a "yes", but then I get worried about using tons of phone data on long trips when just having the Navi system displayed in the car.
2nd, can I play music from a separate USB stick, while using Android Auto?
3rd, is Google Earth an option in the car, appearing on the Vette's screen?
#62
Received 3,448 Likes
So, I'm thinking of buying a used Z06 which didn't come with the factory Nav or PDR. I know I can live without the PDR, though it will be missed (but not all that often, since I'm not tracking a convertible).
question 2. You can play music from a USB stick while using AA.
question 3. Google Earth is not part of AA. You can google for the compatible apps within AA. Google Earth is not one of them.
#63
question 1. Yes you can use it as GPS, and you will be using data. How you can use it for Navigation without a to and from doesn't make sense to me. It seems if you are navigating you would be going from one place to another?
As for #1, yes, I misspoke. I meant using Google Maps as simply a road map with traffic info, as opposed to a "point a to point b" direction-giver. For example, you can just display the map on a factory navigation system as you move along a road, without having to put in a destination. Same for Google Maps. I assume you can just his the map icon in AA and see where you are and check traffic without having to put in a final destination.
But this will use the phone's data, which is the only real downfall of using AA constantly.
#64
I use AA all the time and I'm always under guidance (with a route). I never worry about any data the phone may be downloading.
#65
If you put AA into map mode you'll see a map, you'll see where you are and it'll move with you. I don't think you'll get any traffic info. Why would you. Google Maps doesn't know where you're going! There may be traffic ahead of you but GM doesn't know if you're gonna make a right turn in 10 ft!
Google Maps shows the coming traffic, you know, with the red lines.
I don't understand - you have purchased a vehicle for over $50K - maybe $60 or $70K or more. And you're worried about the tiny charge (in comparison) to get unlimited data and not have to worry about GM's downloading data (as well as tons of other times when unlimited data is very, very useful)?!? You can get unlimited data at like $10/month I hear (I don't know, I've had unlimited data since at least 2008!).
#66
My Google Maps does not show the coming traffic unless you're under a route. What do you pay for your cell phone right now? https://www.verizonwireless.com/plans/verizon-plan/ says $80. I'm assuming that's the total price. If you're that tight on money then maybe you should switch to Sprint as they are only $60/month.
#67
#69
$110.00 a month, and company discounts do not apply to it. I checked the other day. They got rid of the 12gig package entirely. But since I carry over gigs of data every month on the 8 gig plan and I DO get the company discount. that's where I'm sticking. Navigation doesn't eat up the data. It's the movies and music that does.
#70
Plus, and this is the big on - Google Voice Recognition and integration with Google services.
If you don't see a purpose then you're just not looking.
#71
Then you haven't looked. The purpose is to allow for a much better infotainment system. Google Maps is far superior to the factory Nav. You can have all kinds of media apps like, for example, BeyondPod, which will run on the main screen. BeyondPod doesn't make an app for MyLink like say Pandora. Sure I can run it on my phone and use Bluetooth and then try to tap the small phone to switch podcasts or whatever. But the point is I don't have to. I can do it on the larger screen with AA.
#72
Yes I started a thread on this in this very forum. Obviously a hardwired connection will have more frequencies in it than something over the air and thus should sound fuller but it also sounds louder. My beef in the other thread is why don't they compensate for the loudness in a similar manner as the old "Loud" button used to do on CD/Cassette decks and HiFi stereos of yesteryear where the "Loud" button would compensate for frequencies naturally lost at lower listening volumes.
#73
Yes I can download the app also but the question is will it work with a 2015 model Z06? In the past they said it could only work with 2016 and up...Is that still the case?
Blvdbrawler (03-23-2017)
