Gasoline brand
Old 11-18-2016, 07:06 AM
Har-ray
Har-ray's Avatar
Default Gasoline brand
Are there any high octane gasoline manufacturers or brands that are better than others, or are they all pretty much the same?
Old 11-18-2016, 07:11 AM
KrikGS
KrikGS's Avatar
Not sure if a marketing gimmick or not, but I've been using Shell Nitro+ premium exclusively in the Vette. For one because it's a top tier gasoline and because of the fuel rewards program saves me a little at the pump.
I'm sure any top tier gasoline should be fine though.
The following 4 users liked this post by KrikGS:
Foosh (11-18-2016), Har-ray (11-18-2016), JimNeedsC7 (11-18-2016), Rwp315 (11-19-2016)
Old 11-18-2016, 07:24 AM
macdaddy548
macdaddy548's Avatar
I used to be a Sunoco fan, but there are fewer and fewer stations in our area these days. I now use Shell for the same reasons stated in the above post.
Old 11-18-2016, 07:32 AM
Patman
Patman's Avatar
Received 1,920 Likes on 1,192 Posts
Any top tier brand will do the trick
The following 3 users liked this post by Patman:
4thC4at60 (11-19-2016), Bunk (11-20-2016), JimNeedsC7 (11-18-2016)
Old 11-18-2016, 08:07 AM
yeller z06
yeller z06's Avatar
For those who don't know: www.toptiergas.com
A friend of mine worked in the oil & gas industry, and basically what he told me is this:
All gas is the same. It all gets sent through the same pipeline, and the regular gas that Shell puts in (in say, Houston) is not the exact same regular gas that Shell pulls out in NJ. Natch regular is different than premium but they use the same pipeline, and they magically know which is which (my words, not his).
It's all in the additives, that's what makes the difference between brands. That's why I never buy Costco/BJs/Sam's gas - it's the same gas, but you're missing a lot of the detergents and whatnot that keep your injectors and valves clean and happy.
Old 11-18-2016, 08:10 AM
2K14C7
Support Corvetteforum!
2K14C7's Avatar
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
I've never used anything but Amoco 93 octane for the past 15 years in my Corvettes.
Bunk (11-20-2016)
Old 11-18-2016, 08:11 AM
KrikGS
KrikGS's Avatar
Costco gas is rated top tier.
Old 11-18-2016, 08:16 AM
Black Rose-MD
Black Rose-MD's Avatar
Shell Premium...and only fill on Tuesday's ($.20 off per gal) for the vette!!! Maryland area
I do use Costco 92 for my Infiniti daily driver and truck
All "top tier"....
Old 11-18-2016, 08:21 AM
Foosh
Foosh's Avatar
Received 16,669 Likes on 8,312 Posts
Ditto on Shell Nitro, but any premium Top Tier fuel will do, which I use exclusively. I also add the appropriate amount of Chevron Techron fuel additive ever 2K miles or so, per the guidance on minimizing the valve deposit buildup characteristic of direct injection engines.
Old 11-18-2016, 08:39 AM
Squeaky Wheel
Squeaky Wheel's Avatar
Which Techron additive? Went to buy some yesterday and found 2 varieties. One for injectors, the other for fuel systems. Guessing they both are basically the same, but thought I'd ask here first.
Old 11-18-2016, 09:18 AM
Foosh
Foosh's Avatar
I use Techron Complete Fuel System Cleaner. It specifically lists the DI engine application.
Squeaky Wheel (11-18-2016)
Old 11-18-2016, 09:20 AM
scott1094
scott1094's Avatar
Won't say you are mistaken but, as I understand it the carbon problem is due to no fuel washing the back of the intake valve. With direct injection the fuel is injected directly into the combustion chamber. Air is the only medium found in the intake track and flowing past the intake valve. Because the PCV system vents into the air stream and that oil mist hits the back of the hot exhaust valve, it cokes and begins to form deposits that will eventually cause problems. Supposedly this is a problem with all gasoline DI engine systems. As for gas, top tier and maybe a can of Techron once a year to keep the fuel tank sensor clean should do it.
Scott
vdavenp802 (11-18-2016)
Old 11-18-2016, 09:41 AM
jcthorne
jcthorne's Avatar
Yes, fuel additives will do nothing to clean valves on a DI engine.
Top tier gas to keep the fuel system clean.
I like Shell gas but the Shell stations around here all want $.40 a gallon more than other top tier stations for premium. Regular is the same price but they gouge on premium and do not post the price at the street.
Old 11-18-2016, 10:09 AM
Patman
Patman's Avatar
It's even worse of a spread up here, most of the Shell stations in the Toronto area are selling premium for $1.209 per liter ($4.57 a gallon!) while the Costco stations here are charging only 99.9 cents per liter ($3.78 per gallon, 79 cents less!) I am pretty sure that Shell has a better additive package than Costco, but Costco up here is top tier as well so I know it's going to keep my fuel system clean (and just to be sure I add a bottle of Regane All in One every couple of years)
Old 11-18-2016, 10:21 AM
iew
iew's Avatar
Shell here!
Old 11-18-2016, 01:14 PM
PegasusCapital
CF Senior Member
PegasusCapital's Avatar
See this posting on the article in Corvette Magazine discussing the LT1 and LT4 direct injection systems: https://www.corvetteforum.com/forums...-about-di.html
Top tier fuel, Techron and an engine oil with a low NOACK rating are all recommendations made by GM
Old 11-18-2016, 01:23 PM
Foosh
Foosh's Avatar
Every time this subject comes up, a whole bunch of people who haven't read previous discussions pop in and say the same thing. So, here we go again for all the naysayers:
Yes, I'm VERY familiar w/ the DI design and the problem of coking on the tops of valves because they are not washed with fuel additives as they are in port injection.
However, GM says they've addressed the issue in the LT1, and the article mentioned in post 16 above discusses this matter in detail. In particular, GM claims there is some backwash of fuel, as well as other countermeasures to minimize oil mist and alleviate coking. Of course, only time will tell if they were successful.
They also specifically recommend using Top Tier gas exclusively, using Techron periodically, and an oil with the lowest possible NOACK number.
Read the article!
https://www.corvette-mag.com/issues/...n#.WC9HcPnx5aR
Last edited by Foosh; 11-18-2016 at 01:32 PM. Reason: Article link re-posted for convenience
fnbrowning (11-18-2016)
To Gasoline brand
Old 11-18-2016, 03:43 PM
T_B
T_B's Avatar
Chevron for me.
joemessman (11-18-2016)
Old 11-18-2016, 04:16 PM
ATC
ATC's Avatar
Shell. Always.
Old 11-18-2016, 04:34 PM
vdavenp802
vdavenp802's Avatar
This is partially true. All gas is the same. Octane levels are different but gas is the same. Any additives are loaded at the time the transport tanks fill the truck. So, regional additives are based on weather, altitude, etc are different ( not better, just different). Nothing magical about it as gas in the actual pipeline does not know 'brand'. Do the additives really work to improve things, I don't know. I've never been able to tell. But, I do know the amount of specific additives is small, about a quart/8000 gallons. You be the judge.
I too worked for a pipeline company for many years. Watched transports getting loaded from storage tanks. I can assure you the storage tanks did not have brand names on the.
Quick Reply: Gasoline brand
