New owner with a few questions
Hello Everyone. Picked up a new 16 all black Z51 last week. A few questions for the long-time owners:
I have XPEL on my Camaro. Works great on the car whether on street or track events. Placed in strategic locations on the Camaro and 0 issues after 4 years. Would you guys recommend XPEL? Something else you prefer? what locations should I concentrate on?
The 2 plastic air dams on either side of the bumper rub on my driveway. I used 2 way tape to attach a couple plastic strips to the bottom of air dams. Anyone have a better solution? I'm sure some of you will laugh at me for this and that's fine, but it's my car and i'm picky.
Floor mats, what do you guys use? I still have the dealer paper ones over the factory mats. Is weathertech best or is there a more reasonably priced solution that fits?
Lastly, a whole lot of room in the back. Best way to secure cargo? Should I just buy a cargo net?
Thanks everyone
Thanks everyone
Thanks everyone
Thanks everyone
Thanks everyone
Thanks everyone
Beside the well documented aerodynamic properties that they provide at higher speeds, they also serve as an early-warning device for clearance issues on the car. I'm not sure what you mean when you talk about the tape at the bottom of them.
Do you have pics that might explain this a little better?
Thanks everyone
Thanks everyone
Lloyds mats are the top choice, and best IMHO. Had them on all previous Vettes, and have them in both of our C7's. Some site vendors have very good pricing.
The C7 cargo cover works well, and is easy to put on and take off. You can also get the cargo net for the rear.
E-Ray, 3LZ, ZER, LIFT
Received 9,655 Likes
The air dams are expendable, cheap to replace if you so feel compelled, and as stated give warning before hitting the radiator support, which is a bad thing. Get used to pulling in driveways and taking steep angles and dips at an angle. And don't worry about the sound - as long as it isn't the bumper or the supports you're good to go.
I also installed Lloyds Mats, better than OEM.
Below are 2 pics of what I use to carry groceries etc in the rear! Made a collapsible wood partition for a carrier from Bed Bath & Beyond! More info for the OP in this PDF if interested: http://netwelding.com/Rear_Cargo_Area.pdf
Use a Fender Protector I put over spoiler when putting heavy items in the back. Collapsed Carrier fits flat when not in use.
Made wood inserts to hold grocery bags, milk etc. They lay flat when not in use.
Lloyds Mats are great.
robertbruce (09-21-2016)
Thanks everyone for your input. Here's the pic someone requested. I don't want to get rid of them, I'm just wondering if there's a better solution than the strips of plastic I two-way taped on. (For the Camaro, zl1addons makes splitter guards) just wondering if there's a better solution for the Vette.
Also, I have a 1lt with the z51 package. Do the privacy shades and netting come with a higher package? Nothing in the trunk. Just the factory battery tender, the rings and the fuel nozzle. Am I missing stuff?
I track my 1LE sometimes so I have plans of occasionally tracking this car as well. The z51, magnetic ride/PTM was far more important to me than 2 or 3 LT. Just wondering if the shades and netting is on higher optioned cars or if I'm just missing mine.
Looks like you added some door edge trim to the air dam. Good idea! I'll just sand mine off occasionally as I did in my C6! Hard to see unless you bend down and I really don't care what the ants see! Actually my C7 does not scrap when I leave my driveway where my C6 did almost every time. Plus on a Z51 only have them on the ends.
LT4CMG (09-21-2016)
Thank you Jerry. And that is one beautiful interior on your car
Thanks everyone
Thanks everyone
I've seen people custom make a ramp for the front gutter of the driveway to eliminate scrapping.
I use Lloyd's floor mats in front and WeatherTech cargo mat in the rear. Both are excellent products.
I also bought a 3 section cargo net off Amazon that works great in place of the GM net.
Search the forum to find more info on all these items. There's a wealth of info buried here. And most of all, go out and enjoy your ride, it's awesome!!
LT4CMG (09-21-2016)
Thanks. This is another pic. However they changed the 3LT Kalahari and it no longer has the large amount of tan leather on the dash! For my planned GS will probably go with a 2LT two tone gray which will look OK with the black leather on the dash. Saves money so I can add other options and later mods!
2014 3LT Kalahari
2014 3LT Kalahari
I highly recommend Xpel Ultimate. Had the entire front forward of the doors done plus mirrors, headlights & rockers. I also recommend adding side skirts and splash guards to reduce damage from road rash coming off the tires. ACS Composite makes high quality products.
LT4CMG (09-22-2016)
Received 8,958 Likes
Thanks everyone
Thanks everyone
I have Xpel on my car. I do a lot of track events and it is getting some damage. Something flew off the front wheel at VIR and put a couple of digs in the Expel film on the rear brake ducts. The product is not self healing.
The key places to add a protection film like Expel is on the lower sides of the car. The front just doesn't get that much damage from other cars on the street. Your own tires will throw up far more debris onto the side and rear quarters of the car. You aren't driving a CUV or SUV where the crap from the wheels hits the underside of the car.
I just use the factory floor mats. If they wear out I will replace them with factory ones or if they aren't available I will get some aftermarket ones. Not Weathertech. The factory ones in my 2003 Tahoe are still doing fine although the driver's mat has all of the carpet worn off it where my heel rests when my foot is on the gas pedal. Almost 110K miles and 17 years and the factory mats did well.
Bill
