New XK rear diffuser review and install
What the heck happened to your garage walls
i like what you've done, with minor changes, you completely changed the look of the car.
IMHO, nearly $800 is still way too much money for a diffuser. I know, i keep seeing some vendors wanting a whole lot more... i just don't get it... some stuff i see should be costing a couple of hundred bucks but they are peddling them for a couple of thousand.
I could understand better if they are true carbon fiber parts, but most are either plastic or fiberglass.. so relatively cheap to punch out....
guess for those that $$$$ is no object
You must make a template of each splitter, get paper that is bigger than the splitter, then trace the outside and mark the holes , cut the paper and stick it to the splitter, put the splitter on the car once you find the correct spot get tape and mark the out line of the splitter on the valance, it not easy because the splitter might move maybe some help would be required, then remove the splitter and the tape is on the black valance outlining where the splitter goes, then get the paper cut out put it within the lines you marked off and drill the holes. Hopes this helps.
You know I have had 7 vettes and always customize them how I like , and have been on many forums thru the years and you are the one constant I have always found in every forum , the idiot that has always something negative to say, buddy you are the clown and you don't even know it.
bapd77 (10-06-2017)
Nice job Hayabusa! Looks great
[QUOTE=sTz;1593105039]Nice job Hayabusa! Looks great [/QU
Thank you.
Thank you.
Just received the same diffuser and got it back from paint today! I will install this Wednesday and post pictures here!
Received 1,762 Likes
#35
Installed with photos!
Turned out nicely, what do you think?
bapd77 (10-06-2017)
#37
Can you please give me a photo of the direct rear of the car, but standing about 15 feet or so back and the camera about level with the taillights?
I know that's a specific request, but trying to grasp how this looks on the base car from a little distance.
If possible, thank you!
#38
#39
No problem! hope this helps a bit, photos I took after install I had on the phone. I can try to take more if needed!
